Module ModuleBuilder
Revision as of 17:55, 21 March 2024 by Abdel (talk | contribs) (→‎Usage)
Foundations
Numero/ID of module 3300
Developer doc. of module
The ModuleBuilder is a module for developpers only, to help you to develop a module. It is RAD, No Code or Low Code tool.
The ModuleBuilder within Dolibarr presents a lot of features designed for the comprehensive management and development of moduleLanguage Support:
  • Language Support:
    This function allows developers to introduce additional languages into a module, enhancing its accessibility and usability across different linguistic demographics. It involves integrating new language files or entries that translate the module's interface and messages.
  • Menus:
    Enables the crafting of custom menus within the module's UI, allowing users to navigate through the module's features more efficiently. This might include adding new menu items linked to specific functionalities or adjusting the module's navigation structure.
