Module ModuleBuilder
Revision as of 17:40, 21 March 2024 by Abdel (talk | contribs) (→‎Usage)
Foundations
Numero/ID of module 3300
Developer doc. of module
The ModuleBuilder is a module for developpers only, to help you to develop a module. It is RAD, No Code or Low Code tool.
The ModuleBuilder within Dolibarr presents a lot of features designed for the comprehensive management and development of modules.
  1. Adding Language Support:
    This function allows developers to introduce additional languages into a module, enhancing its accessibility and usability across different linguistic demographics. It involves integrating new language files or entries that translate the module's interface and messages.
