Module HelloAsso
| Module name | HelloAsso |
Dolibarr min version: 20 Dolibarr max version: {{{maxversion}}} |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2024-03-19 |
| Note / Nota |
Add into Dolibarr, a HelloAsso online payment page (credit/debit cards). This can be used to allow your customers to make ad-hoc payments or payments related to a specific Dolibarr object (invoice, order etc...)
Prerequisites
This module requires an instance of Dolibarr version 20 or +.
From the application
Manually
unzip modulefile.zip
Setup for sandbox mode
Setup for live mode
Development and contributions
- Repository: https://github.com/DoliCloud/DoliMods.git
