Module HelloAsso
Revision as of 15:33, 18 March 2024 by Hystepik (talk | contribs) (Created page with "<!-- BEGIN origin interlang links --> <!-- You can edit this section but do NOT remove these comments Links below will be automatically replicated on translated pages by...")
Module name HelloAsso
Download or buy page / Page achat ou téléchargement External module - On Dolistore, On Google play
Status / Statut / Estado
Dolibarr min version: See on Dolistore
Last update date / Date mise à jour fiche / Fecha última actualización 2024-03-18
Prerequisites
This application need Android 6.0+ and an online hosted Dolibarr ERP & CRM version 8.0+ (for example an online instance provided by one of the SaaS/Cloud hosting provider).
If your Dolibarr is not installed in a cloud or a hosted server, but on your own local computer at home, you must be sure to have setup your ADSL box so you can reach your computer from outside home with an external internet access, on the port where dolibarr run (port 80 in most cases). This is an example on how to do this for O2 customer: http://www.o2help.co.uk/router-port-forwarding/ (replace port 5070 with 80).
Development and contributions
Troubleshooting
