Module Accounting Export DATEV-Format
Revision as of 13:01, 21 February 2024 by Priojk (talk | contribs)
Information
Module name Accounting Export DATEV-Format
Editor / Editeur Bloxera GmbH - https://www.bloxera.com
Download or buy page / Page achat ou téléchargement External module - tbd.
Status / Statut / Estado
Last update date / Date mise à jour fiche / Fecha última actualización 2024-02-21
Note / Nota Find a detailed description of the module and its settings here: https://www.dolicenter.com/accounting-export-datev.php
Dolibarr has many built in import formats for double entry accounting. This modules adds an additional export format (DATEV-format) which is very common in Germany.
More info
Module description (in German): https://www.dolicenter.com/accounting-export-datev.php
