Module Accounting Export DATEV-Format
Information
Module name | Accounting Export DATEV-Format |
Editor / Editeur | Bloxera GmbH - https://www.bloxera.com |
Download or buy page / Page achat ou téléchargement | External module - tbd. |
Status / Statut / Estado | |
Prerequisites / Prérequis |
Last update date / Date mise à jour fiche / Fecha última actualización | 2024-02-21 |
Note / Nota | Find a detailed description of the module and its settings here: https://www.dolicenter.com/accounting-export-datev.php |
Dolibarr has many built in import formats for double entry accounting. This modules adds an additional export format (DATEV-format) which is very common in Germany.
