Module AccountingExport
Revision as of 12:48, 21 February 2024 by Priojk (talk | contribs)
Information
Module name AccountingExport
Editor / Editeur Bloxera GmbH - https://www.bloxera.com
Download or buy page / Page achat ou téléchargement External module - https://www.dolistore.com/de/moduleplugins/1659-AccountingExport.html
Status / Statut / Estado
Last update date / Date mise à jour fiche / Fecha última actualización 2024-02-21
The export of accounting data may be required for the collaboration with a tax advisor or to use specialized accounting software.
Dolibarr supports various export formats out-of-the-box. Unfortunately, none of them is widely used in Germany. The purpose of this module is to provide additional target formats for the export of accounting data, in particular for the use in Germany.
Currently, the export to the following format(s) ist supported:
  • Export for Taxpool (accounting software used in Germany)
Use
Once activated, the target format can be selected in the drop down list via
  • accounting -> setup -> export options
The export of the accounting data can be initiated like so:
  • accounting -> accounting -> journals
  • and then click on the export symbol in the top right area
Note
Please note that this module has not yet been extensively used in production. Use with caution. In case of problems, your feedback is appreciated.
