Module EMail Collector
Revision as of 10:07, 25 January 2024 by Hystepik (talk | contribs) (→‎Test)
EMailCollector
Numero/ID of module 50320
Developer doc. of module Module EMail Collector (developer)
This module permits to collect emails from a mailbox using the IMAP protocol and record event or data in your Dolbarr using information found into email.
Create an email collector
Create as many email collector you need.
Source directory
  • To collect received email, enter here "INBOX"
  • To collect email sent, enter here "Sent"
Target directory A good practice is to move the collected email into another folder to avoid to have them collected twice. You must create the output target IMAP directory manually before running your email collector.
For example, with Gmail, to create a new IMAP directory:
  • Sign in to your Gmail account.
  • At the top right of the Gmail window, click Settings See all settings.
  • Click Labels.
  • Create Label and check the box "Show in IMAP"
Filters
Operations to do
Let the job scheduler being executed automatically and see your data being recorded into Dolibarr.
To avoid to wait the batch, you can force to execute the email collector manually from the Email collector record with the button "Run now". When making test, a good practice is to set the maximum number of email collected to a low value.
A test mode is available. This mode does not cause any modification of your mailbox (just reading) nor modification in Dolibarr. On the other hand, it allows you to see the different stages of selection, the filter and the processing that would be applied if we were not in test mode.
Boundary Value Analysis
User Stories
Story KO / OK Errors / Problems
Collect received mails OK
Collect send emails OK
Send email from Dolibarr and don't collect it because it will be a double KO Cannot send email from Ticket tab
Filters
Filters KO / OK Errors / Problems
From OK
To OK
Cc KO Search string not understood - Unknown search criterion: CC
Bcc KO Search string not understood - Unknown search criterion: BCC
ReplyTo OK Works every time even if the Reply to string isn't in the mail
Subject OK
Body OK
Already read OK
Unread OK
Unanswered OK
Answered OK
Size (Smaller than) KO Search string not understood - Unknown search criterion: SMALLER
Size (Larger than) KO Search string not understood - Unknown search criterion: LARGER
Message from a conversation initiated by a first email sent from Dolibarr OK
Message from a conversation initiated by a first email NOT sent from Dolibarr OK
Message sent from Dolibarr OK
Message NOT sent from Dolibarr OK Message not processed but not an error
Is not answer (initial email) OK
Is an answer of an initial email OK
