Module Point of sale (TakePOS)
Point of sale (TakePOS) | |
Numero/ID of module | 50150 |
Developer doc. of module | Module Point of sale TakePOS (developer) |
This module transforms your Dolibarr into a Point Of Sale (POS). It is an advanced Point of Sale with plenty of supported features like:
- Parallel sales
- Bar-code reader compatibility
- Touch and Responsive interface
- Multi-terminal
- Multi-payment mode, multi-payment sessions
- Auto order by customer from a QR code
- Management of shops, bars or restaurant
Note that this module should be used to replace the older Module Point of sale (SimplePOS)
Hardware compatibility
If you need to connect the TakePOS module with some external hardware, you may find information on some compatible hardware ont this page: https://takepos.com/hardware/
Example of hardware setup for receipt printers:
A) Using your browser print feature
This solution is the one available by default, it uses the standard "Print" feature of your browser.
If you can print from your local computer (from your browser) on your standard printer, you should be able to print TakePos receipts with no need of special setup. TakePos will open the receipt in a popup on your browser as well as the print option of your browser will also open so all you have to do will be to click on the Print button.
+--------+ +------------------------+ +-----------------+ |The | lan/wan | Browser print system | | Dolibarr server | |Printer |<----or usb ----| of your local computer |--internet-->| with TakePOS | +--------+ +------------------------+ +-----------------+
Limitation: This feature is no able to use serial POS printers but any common printers (wifi, lan, usb) are supported with no need for special setup.
B) Using the old "Java connector"
This method is now deprecated.
+--------+ +----------------+ +---------------------+ +---------------------------+ |The | serial | Java connector | | Your local computer | | Dolibarr server | |printer |<--or usb--| on the printer |<--tcp/ip--| Browser |--internet-->| with TakePOS | | | | | | | | + module "Java connector" | +--------+ +----------------+ +---------------------+ +---------------------------+
Video demo here: https://www.youtube.com/watch?v=VLZG9BZ0HLs
C) Using the "old Web" TakePOS connector
+--------+ +------------------+ +---------------------+ +--------------------------+ |The | serial | Web server | | Your local computer | | Dolibarr server | |printer |<--or usb--| with the |<--tcp/ip--| Browser |--internet-->| with TakePOS | | | | Web Takepos conn | | | | + module "New connector" | +--------+ +------------------+ +---------------------+ +--------------------------+
Once the module "New connector.zip" on Dolibarr has been installed, you must choose the print method "TakePOS connector".
Video demo here: https://www.youtube.com/watch?v=AyQLOT0-SIY
D) Using the new Java "Hardware Bridge" server for WebApps and TakePOS connector 18+
Module for Dolibarr can be downloaded here: https://www.dolistore.com/en/modules/1889-TakePOS-Connector.html
+--------+ +-----------------+ +---------------------+ +----------------------------------+ |The | serial | Java | tcp/ip | Your local computer | | Dolibarr server | |printer |<--or usb--| hardware bridge |<--websocket-->| Browser |--internet-->| with TakePOS | | | | port 12212 | | | | + module TakePOS connector 18.0+ | +--------+ +-----------------+ +---------------------+ +----------------------------------+
Setup of Dolibarr module: With TakePOS connector 18+, as soon as the module is activated, TakePOS will use the Java server "Hardware bridge" as print method. To switch back to use the browser, you must disable the module. The Java server accept websocket from the browser of the local computer. So when the server is stopped or restarted, it can warm the browser with a popup. The local browser (The module TakePOS connector) is sending the print request by sending the Raw text content encoded in Base64.
Setup of the Java hardware Bridge:
This gateway run on Windows (or Linux but dev for Linux is not complete). You can download a release at https://github.com/imTigger/webapp-hardware-bridge/releases/. Click on a the version you want, so you will reach the list of files to download.
For a bridge on Windows: Download and execute the whb-x.y.0.exe and run it. This will install and run the server. Also, from the board of running application, you will find an icon that allow you tu run the Configuration. Run the configuration and select the POS serial printer. If you don't have a POS serial printer, you can select "Fallback to default printer", then install a virtual POS driver (like the EMF Virtual Printer available at https://www.colorpilot.com/emfprinter_versions.html) and finally set this virtual Driver as the default printer.
For a bridge on Linux: You can download the zip file with the java server and run the java server by launching the jar file from the command line with: java -jar webapp-hardware-bridge.jar However, it seems not possible to run the Configurator to select the printer to use. So on Linux, this server may not work properly.
Related videos
