Module Point of sale (TakePOS)
| Point of sale (TakePOS) | |
| Numero/ID of module | 50150 |
| Developer doc. of module | Module Point of sale TakePOS (developer) |
This module transforms your Dolibarr into a Point Of Sale (POS). It is an advanced Point of Sale with plenty of supported features like:
- Parallel sales
- Bar-code reader compatibility
- Touch and Responsive interface
- Multi-terminal
- Multi-payment mode, multi-payment sessions
- Auto order by customer from a QR code
- Management of shops, bars or restaurant
Note that this module should be used to replace the older Module Point of sale (SimplePOS)
Hardware compatibility
If you need to connect the TakePOS module with some external hardware, you may find information on some compatible hardware ont this page: https://takepos.com/hardware/
Example of hardware setup for receipt printers:
A) Using your browser print feature
This solution is the one available by default, it uses the standard "Print" feature of your browser.
If you can print from your local computer (from your browser) on your standard printer, you should be able to print TakePos receipts with no need of special setup. TakePos will open the receipt in a popup on your browser as well as the print option of your browser will also open so all you have to do will be to click on the Print button.
+--------+ +--------------------------+ +-----------------+ |The | | Browser print system | | Dolibarr server | |Printer |<----lan/wan/usb----| of your local computer |----internet---->| with TakePOS | +--------+ +--------------------------+ +-----------------+
Limitation: TODO
B) Using the old "Java connector"
This method is now deprecated.
+--------+ +----------------+ +--------------------------+ +-----------------+ |The | | Java connector | | Your local computer | | Dolibarr server | |printer |<--serial/usb--| on the printer |<--tcp/ip--| Browser |----internet---->| with TakePOS | | | | | | | | + module | +--------+ +----------------+ +--------------------------+ +-----------------+
Video demo here: https://www.youtube.com/watch?v=VLZG9BZ0HLs
C) Using the old Web TakePOS connector
+--------+ +------------------+ +--------------------------+ +------------------------------------+ |The | | Web server | | Your local computer | | Dolibarr server | |printer |<--serial/usb--| with the |<--tcp/ip--| Browser |----internet---->| with TakePOS | | | | Web Takepos conn | | | | + module "New connector.zip" | +--------+ +------------------+ +--------------------------+ +------------------------------------+
Once the module "New connector.zip" on Dolibarr has been installed, you must choose the print method "TakePOS connector".
Video demo here: https://www.youtube.com/watch?v=AyQLOT0-SIY
D) Using the new WebAPP TakePOS connector
Module for Dolibarr can be downloaded here: https://www.dolistore.com/en/modules/1889-TakePOS-Connector.html
+--------+ +------------------+ +--------------------------+ +------------------------------------+ |The | | Web server | | Your local computer | | Dolibarr server | |printer |<--serial/usb--| with the WebApp |<--tcp/ip--| Browser |----internet---->| with TakePOS | | | | hardware bridge | | | | + module "TakePOS connector 18.0+" | +--------+ +------------------+ +--------------------------+ +------------------------------------+
ToComplete...
Related videos
