Module Point of sale (TakePOS)
| Point of sale (TakePOS) | |
| Numero/ID of module | 50150 |
| Developer doc. of module | Module Point of sale TakePOS (developer) |
This module transforms your Dolibarr into a Point Of Sale (POS). It is an advanced Point of Sale with plenty of supported features like:
- Parallel sales
- Bar-code reader compatibility
- Touch and Responsive interface
- Multi-terminal
- Multi-payment mode, multi-payment sessions
- Auto order by customer from a QR code
- Management of shops, bars or restaurant
Note that this module should be used to replace the older Module Point of sale (SimplePOS)
Hardware compatibility
If you need to connect the TakePOS module with some external hardware, you may find information on some compatible hardware ont this page: https://takepos.com/hardware/
Example of hardware setup for receipt printers:
Printer linked to your local desktop
This solution, available by default, will use the standard "Print" feature of your browser.
If you can print from your local computer (from your browser) on your printer, you should be able to print TakePos receipts with no need of special setup. TakePos will open the receipt in a popup on your browser as well as the print option of your browser will also open so all you have to do will be to click on the Print button.
+--------+ +--------------------------+ +-----------------+ |The | | Browser print system | | Dolibarr server | |Printer |<----lan/wan/usb----| of your local computer |----internet---->| with TakePOS | +--------+ +--------------------------+ +-----------------+
Using the old Java connector
This method is now deprecated.
+--------+ +----------------+ +--------------------------+ +-----------------+ |The | | Java connector | | Your local computer | | Dolibarr server | |printer |<--serial/usb--| on the printer |<--tcp/ip--| Browser |----internet---->| with TakePOS | | | | | | | | + module | +--------+ +----------------+ +--------------------------+ +-----------------+
Video demo here: https://www.youtube.com/watch?v=VLZG9BZ0HLs
Using the old Web TakePOS connector
+--------+ +------------------+ +--------------------------+ +------------------------------------+ |The | | Web server | | Your local computer | | Dolibarr server | |printer |<--serial/usb--| with the |<--tcp/ip--| Browser |----internet---->| with TakePOS | | | | Web Takepos conn | | | | + module "New connector.zip" | +--------+ +------------------+ +--------------------------+ +------------------------------------+
Video demo here: https://www.youtube.com/watch?v=AyQLOT0-SIY
Using the new WebAPP TakePOS connector
Module for Dolibarr can be downloaded here: https://www.dolistore.com/en/modules/1889-TakePOS-Connector.html
TODO
Life cycle / Business rules
Related videos
