Application Android - Mobilid EN
Revision as of 11:18, 28 November 2023 by Eldy (talk | contribs)
Module name PHPSysInfo
Editor / Editeur Z-Application - www.mobilid.eu
Download or buy page / Page achat ou téléchargement External module - www.dolistore.com - Google Play
Prerequisites / Prérequis Dolibarr min version 3.2.0
Last update date / Date mise à jour fiche / Fecha última actualización 2023-11-28
Mobilid can do Stock inventory, Customer order collecting, Supplier order dispatching Order creating and Prospect contacting. Mobilid has build in barcode scanning and can connect to bluetooth barcode scanners. Add product photo to Dolibarr using device camera. Build in Mobile Device Managment.
When installed in custom folder you will have to choose the 'dolibarr custom' connector in the Mobilid app main settings.
You can read the full documentation at https://docs.z-application.com
