Table llx adherent options label
Revision as of 10:53, 24 October 2023 by Eldy (talk | contribs)
Content/Contenu/Contenido
En verysmall.png Contains the label of optional attributes to describe members in foundation module
Fr verysmall.png Contient les étiquettes des attributs optionnel des adhérents du module association
Es verysmall.png Contiene las etiquetas de los atributos opcionales de los miembros del módulo miembros
Structure
Table
rowid int(11) NO PRI auto_increment technical index
name varchar(64) NO UNI index
entity int(11) NO UNI 1 multi company id
tms timestamp NO Current date Date of last modification. See page Field Tms.
label varchar(255) NO label corresponding to the attribute
type varchar(8) YES NULL attribute type
size int(11) YES 0 attribute size
pos int(11) YES 0 attribute position
Keys
Key Type Fields
PRIMARY PRIMARY rowid
uk_adherent_options_label_name UNIQUE name,entity
