Module AddressAssistant
Revision as of 19:09, 19 October 2023 by Priojk (talk | contribs)
Information
Module name AddressAssistant
Editor / Editeur Bloxera GmbH
Download or buy page / Page achat ou téléchargement External module - https://www.dolistore.com/en/modules/1888-Address-Assistant-DE-AT-CH-LI.htm
Status / Statut / Estado
Last update date / Date mise à jour fiche / Fecha última actualización 2023-10-19
Based on the entry of post code (zip) or city name, the rest (post code, city name, federal state/canton and country) get proposed and auto-filled. Works in address forms of customers, suppliers, prospects etc. within Dolibarr. The module is offered in different versions. It contains all post codes, cities and federal states/canton of the specified country (or countries).
Use
Entering correct addresses made quick and easy: This module provides a comfortable auto-fill function for all forms in Dolibarr, where addresses are entered (e.g. third parties, contacts, etc.).
  • Just type the post code (zip code) and select a related city from a drop down list. City name and federal state/canton will be entered automatically into the respective entry fields.
  • Alternatively, type the city name and select the post code from the available options in a drop down list and have the post code (zip code) and federal state or canton automatically entered.
  • All entered addresses now have the federal state or canton automatically assigned. In many cases, this information has not been entered before, but it can be a valuable selection criteria in the future, e.g. for targeted marketing activities.
There is nothing to set up or configure. Just activate the installed module and you are ready to go.
Updates
Any updates of this module are included within one year after purchase.
