Module Lot / Serial | |
Numero/ID of module | 39000 |
Developer doc. of module | Module Lot / Serial (developer) |
ProductBatch module allow user to manage the following fields:
- Serial number
- Sell-by date = Shelf life expiration date = Use by (foods must be removed from store after this date)
- Eat-by date = Best Before date = Best if Used By = Best by (eat-by-date is often > sell-by-date)
This module extends Module Stocks En.
There is no setup for this module but you will need at least to configure decreasing / increasing option in stock module for good operation.
- Stock decrease : on shipment validation
- Stock increase : on manual dispatch
On a product, you can decide if the product need a lot or a unique serial numero. If you set a product to need such a number (whatever is a lot or a serial number), no stock movement will be allowed if you don't enter also this number/numero.
The first time a lot/serial is known by Dolibarr, this lot/serial is recorded into table llx_product_lot with the date of creation. This record will remain indefinitely into this table. Also if you enter a Sell-by date or a Eat-by date, this date(s) will also be recorded into this table. This date are specific to a lot. So when making future stock movement, you don't have to re-enter this dates, the lot/serial number is enough. If you try to make a stock movement with an already existing lot and you try to force the Date Sell-by or Eat-by with a different date, the stock movement will be denied. Dates are expected only the first time a new lot appear, then they must be similar to the one defined the first time, or they must not be provided.
