提供REST API的Web服务模块(开发者)
Revision as of 03:35, 9 October 2023 by ShengGang (talk | contribs) (→‎安装)
Web services
模块ID 2610
用户手册 不适用
开发文档 本页
功能
激活此模块后,您就可以调用Dolibarr提供的Webservices。然后,您可以对Dolibarr提供的各种Web服务进行REST调用。
安装
要安装它,请打开 主页->设置->模块/应用 并激活"API / Web 服务 (REST 服务器)"模块。
激活 API / Web 服务 (REST 服务器) 模块后,Dolibarr 将成为REST Web服务器。您可以在相应的URL上发送自己的REST请求 : /api/index.php/xxx 其中xxx是要调用的API的名称。 A list of APIs on your installation can be found via the explorer. Click on link to explorer to open the API explorer.
Apache setup
There is nothing to do. If your Dolibarr is working with Apache, the REST API should also work. APIs will be served by the same virtual web server than your application.
Nginx setup
Like Apache, if your Dolibarr is working inside a NGinx virtual host, you should have nothing to do to have your API working. APIs will be served by the same virtual web server than your application.
However, NGinx default setup on a lot of distribution is often a gaz engine and you may experience troubles. If you experience such troubles, you can try to edit your NGinx config file to match the following example. This is a simple localhost setup with a working REST API handling (tested with 9.0.1 on parabola gnu/linux).
worker_processes  1;
error_log  /var/log/nginx/error.log;
events {
    worker_connections  1024;
http {
    include       mime.types;
    default_type  application/octet-stream;
    #log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
    #                  '$status $body_bytes_sent "$http_referer" '
    #                  '"$http_user_agent" "$http_x_forwarded_for"';
    #access_log  logs/access.log  main;
    sendfile        on;
    #tcp_nopush     on;
    #keepalive_timeout  0;
    keepalive_timeout  65;
    #gzip  on;
    server {
    	listen		80;
        server_name     dolibarr.localhost; # adjust to your domain
        root    /usr/share/webapps/dolibarr/htdocs; # adjust to your path
        index   index.php;
        # from https://github.com/Dolibarr/dolibarr/issues/6163#issuecomment-391265538
        location ~ [^/]\.php(/|$) {
            fastcgi_split_path_info ^(.+?\.php)(/.*)$;
            if (!-f $document_root$fastcgi_script_name) {
                return 404;
            # Mitigate https://httpoxy.org/ vulnerabilities
            fastcgi_param HTTP_PROXY "";
            fastcgi_pass   unix:/run/php-fpm/php-fpm.sock;
            fastcgi_index  index.php;
            include        fastcgi_params;
            fastcgi_param  SCRIPT_FILENAME $document_root$fastcgi_script_name;
            # Dolibarr Rest API path support
            fastcgi_param  PATH_INFO       $fastcgi_path_info;
            fastcgi_param  PATH_TRANSLATED $document_root$fastcgi_script_name;
Liste des services fournis
Seuls quelques services sont disponibles. À compter de la version 5.0 de Dolibarr, vous pouvez consulter la liste complète des web services proposés en appelant l'explorer à cette adresse :
http://yourdolibarrurl/api/index.php/explorer.
Par exemple, vous pouvez essayer l'explorateur sur l'instance de démonstration à l'adresse suivante :
https://demo.dolibarr.org/api/index.php/explorer
Dans le coin supérieur droit, collez le <token> de l'utilisateur que vous souhaitez utiliser pour appeler l'API, puis cliquez sur le bouton "explorer". Remarque: Le jeton de chaque utilisateur peut être défini sur la page d'enregistrement de l'utilisateur.
Vous pouvez aussi préférer faire un premier appel au service login pour obtenir le jeton API. Vous aurez en réponse le jeton à utiliser pour obtenir et appeler la liste des services proposés.
Après avoir saisi le jeton et cliqué sur "Explore", vous devriez voir toutes les actions disponibles avec ce jeton. Si vous n'avez pas beaucoup d'actions, c'est probablement parce que les modules correspondants ne sont pas activés. Si vous voulez voir les factures, vous devez activer le module Factures dans la configuration de Dolibarr. Même chose pour les Produits, les Tiers, etc.
Vous pouvez ensuite tester directement à partir de cet explorateur n'importe quelle API. Ceci est la solution recommandée pour tester toute API Dolibarr, car toutes les API et paramètres sont documentés ici. À la suite d'un test, vous obtiendrez la réponse, mais également un exemple sur la façon d'appeler l'API à partir de la ligne de commande à l'aide de curl.
Sur cette page d'exploration de l'API, vous pouvez faire beaucoup de tests. Lire des données de Dolibarr et écrire, modifier et supprimer également. Attention: les données sont vraiment modifiées dans votre base de données.
使用方法
Grosso modo, pour utiliser REST, il faut appeler une url du genre suivant http://<mon_serveur>/api/index.php/<action>
avec une des 4 méthodes : GET, POST, PUT, DELETE, en remplaçant <action> par l'action sur laquelle vous voulez intervenir. Ex : http://<mon_serveur>/api/index.php/invoices
Avant d'utiliser une API, vous devez d'abord obtenir une clé API personnalisée. Vous devez créer un nouvel utilisateur et générer ou définir sa "clé pour l'API".
Vous devrez utiliser cette clé API dans n'importe lequel de vos programmes clients devant appeler une API Dolibarr.
Pour ce faire, il existe plusieurs méthodes. Voici un morceau de code opérationnel pour appeler une API, mais il existe également des librairies qui simplifie le travail, telles que phphttpclient.com.
function CallAPI($method, $apikey, $url, $data = false)
    $curl = curl_init();
    $httpheader = ['DOLAPIKEY: '.$apikey];
    switch ($method)
        case "POST":
            curl_setopt($curl, CURLOPT_POST, 1);
            $httpheader[] = "Content-Type:application/json";
            if ($data)
                curl_setopt($curl, CURLOPT_POSTFIELDS, $data);
            break;
        case "PUT":
	    curl_setopt($curl, CURLOPT_CUSTOMREQUEST, 'PUT');
            if ($data)
            break;
        default:
            if ($data)
                $url = sprintf("%s?%s", $url, http_build_query($data));
    // Optional Authentication:
	//    curl_setopt($curl, CURLOPT_HTTPAUTH, CURLAUTH_BASIC);
	//    curl_setopt($curl, CURLOPT_USERPWD, "username:password");
    curl_setopt($curl, CURLOPT_URL, $url);
    curl_setopt($curl, CURLOPT_RETURNTRANSFER, 1);
	curl_setopt($curl, CURLOPT_HTTPHEADER, $httpheader);
    $result = curl_exec($curl);
    curl_close($curl);
    return $result;
Ce n'est qu'un exemple, ce n'est pas sécurisé, cela ne prend pas en compte les codes erreurs mais vous pouvez le modifier et l'adapter à vos besoins. la fonction prend 4 paramètres :
  • $method : string "GET", "POST", "PUT", "DELETE"
  • $apikey : string "votre <token> généré plus haut"
  • $url : string l'url à appeler. Ex : "http://<mon_serveur>/api/index.php/invoices"
  • $data : string flux au format json. Ce champ est requis pour les appels POST ou PUT.
Exemples avec PHP
Maintenant, quelques exemples opérationnels pour différents cas d'utilisation.
Dans tous les cas, on a :
  • $apiKey = "<mon token>";
  • $apiUrl = "http://<mon_serveur>/api/index.php/";
// Récupérer la liste des produits
	$listProduits = [];
	$produitParam = ["limit" => 10000, "sortfield" => "rowid"];
	$listProduitsResult = CallAPI("GET", $apiKey, $apiUrl."products", $produitParam);
	$listProduitsResult = json_decode($listProduitsResult, true);
	if (isset($listProduitsResult["error"]) && $listProduitsResult["error"]["code"] >= "300") {
	} else {
		foreach ($listProduitsResult as $produit) {
			$listProduits[intval($produit["id"])] = html_entity_decode($produit["ref"], ENT_QUOTES);
Commentaires :
  • récupérer les 10'000 premiers produits triés par leur id dans la base
  • html_entity_decode est nécessaire car les apostrophes sont encodés
  • il est facile d'utiliser la même méthode (en remplaçant products par dictionnarycountries) pour récupérer la liste des pays
// Créer un produit
	$ref = "ma_reference_produit_X203ZZ";
	$newProduct = [
		"ref"	=> $ref,
		"label"	=> $ref
	$newProductResult = CallAPI("POST", $apiKey, $apiUrl."products", json_encode($newProduct));
	$newProductResult = json_decode($newProductResult, true);
Commentaires :
  • avant de créer un produit, il peut être sage de vérifier qu'il existe. En reprenant le premier exemple, cela fait :
// ma référence
// existe-t-elle dans mon tableau
	$produitKey = array_search($ref, $listProduits);
	if ($produitKey) {
// oui
		$fk_product = $produitKey;
	} else {
// non
// Créer un produit
		$newProduct = [
			"ref"	=> $ref,
			"label"	=> $ref
		if (isset($newProductResult["error"]) && $newProductResult["error"]["code"] >= "300") {
// il y a eu une erreur
			echo "<pre>ERROR", var_dump($newProductResult), "</pre>";
			exit;
		} else {
// tout va bien
			$fk_product = $newProductResult;
			$listProduits[$fk_product] = $ref;
Commentaires :
  • je regarde si la référence de mon article existe dans le tableau créé dans le premier exemple.
  • si elle existe, j'utilise sa clé dans le tableau comme id
  • si elle n'existe pas, je crée l'article puis le j'ajoute à mon tableau pour les prochaines fois et je récupère l'id créé
  • cette méthode permet de limiter les appels API quand on doit importer 500 commandes par exemple. Récupérer une fois la liste des produits au début au lieu de chercher à chaque fois dans Dolibarr.
// créer une commande avec 2 articles
// le tableau qui contiendra toutes les lignes d'articles de la commande
	$newCommandeLine = [];
// article 1
	$ref1 = "ma_reference_produit_X203ZZ";
	$prix1 = 10;
	$qtt1  = 100;
	$tva1 = 20;
	$fk_product1
// article 2
	$ref2 = "ma_reference_produit_B707FD";
	$prix2 = 13;
	$qtt2  = 37;
	$tva2 = 20;
	$newCommandeLine[] = [
		"desc"		=> $ref1,
		"subprice"	=> $prix1,
		"qty"		=> $qtt1,
		"tva_tx"	=> floatval($tva1),
		"fk_product"=> $fk_product1
		"desc"		=> $ref2,
		"subprice"	=> $prix2,
		"qty"		=> $qtt2,
		"tva_tx"	=> floatval($tva2),
		"fk_product"=> $fk_product2
	if (count($newCommandeLine) > 0) {
		$newCommande = [
			"socid"			=> $clientDoliId,
			"type" 			=> "0",
			"lines"			=> $newCommandeLine,
			"note_private"	=> "Commande importée automatiquement depuis l'application",
		$newCommandeResult = CallAPI("POST", $apiKey, $apiUrl."orders", json_encode($newCommande));
		$newCommandeResult = json_decode($newCommandeResult, true);
Commentaires :
  • $clientDoliId vaut l'id du client dans la base doli. Soit vous le connaissez, soit vous pouvez le chercher auparavant
  • type => 0, c'est une commande client (par opposition à 1 = commande fournisseur)
// Valider une commande
	$newCommandeValider = [
		"idwarehouse"	=> "0",
		"notrigger"		=> "0"
	$newCommandeValiderResult = CallAPI("POST", $apiKey, $apiUrl."orders/".$newCommandeResult."/validate", json_encode($newCommandeValider));
	$newCommandeValiderResult = json_decode($newCommandeValiderResult, true);
Commentaires :
  • on voit dans cet exemple, en avant dernière lignes, on a : $apiUrl."orders/".$newCommandeResult."/validate".
$newCommandeResult est l'id de la commande crée (récupéré dans l'exemple précédent)
// chercher si le client existe dans la base
	$clientSearch = json_decode(CallAPI("GET", $apiKey, $apiUrl."thirdparties", array(
		"sortfield" => "t.rowid",
		"sortorder" => "ASC",
		"limit" => "1",
		"mode" => "1",
		"sqlfilters" => "(t.nom:=:'".$nom_client."')"
	), true);
Commentaires :
  • limit => 1 pour ne renvoyer que 1 client
  • mode => 1 car on cherche un client (on aurait aussi pu chercher un fournisseur qui est aussi un tiers mais avec un statut différent)
  • sqlfilters syntaxe un peu particulière mais il y a qq autres exemples sur la page d'explorer d'API
//client n'existe pas. le crée puis on récupère son id
	$newClient = [
		"name" 			=> "nom société client",
		"email"			=> "email société client",
		"client" 		=> "1",
		"code_client"	=> "-1"
	$newClientResult = CallAPI("POST", $apiKey, $apiUrl."thirdparties", json_encode($newClient));
	$newClientResult = json_decode($newClientResult, true);
	$clientDoliId = $newClientResult;
Commentaires :
  • client => 1 car c'est un client (et pas un fournisseur)
  • code_client => -1 pour que le code client soit généré automatiquement.
  • on récupère l'id du client dans $clientDoliId
Développer un nouveau service / sa propre API
Ajouter un nouveau service est aussi facile qu'ajouter un fichier nommé api_monmoduleobject.class.php dans le dossier htdocs/monmodule/class. Si vous utilisez le "modulebuilder" pour développer sur Dolibarr, cette API avec les méthode CRUD pourra même être générée pour vous. Sinon, un copié-collé d'un fichier API existant fera l'affaire. Vous pouvez prendre comme exemple le fichier dans htdocs/commande/class/api_orders.class.php et l'adapter à votre classe / besoin.
Le framework détecte automatiquement les API et elle devrait être visible dans l'explorateur.
Les méthodes et paramètres sont détectées en fonction de l'introspection réalisée dans les classes PHP de l'objet (htdocs/monmodule/class/object.class.php) en utilisant les annotations trouvées dans la classe.
Pour une documentation à propos des annotations : https://github.com/Luracast/Restler/blob/master/ANNOTATIONS.md
Vous trouverez pas mal d'autres informations dans le code de Dolibarr. Vous trouverez tous les fichiers API de Dolibarr sous le nom htdocs/<dossier>/class/api_xxx_class.php
Vidéos sur le sujet
