导出模块
Revision as of 02:47, 11 September 2023 by ShengGang (talk | contribs) (Created page with "Category:管理 {{Template用户手册}} {{TemplateModZH}} {{模块模板| name=导出| num=240| devdoc=本页| userdoc=本页}} = 简介 = To export Dolibarr data, use t...")
导出
模块ID 240
用户手册 本页
开发文档 本页
简介
To export Dolibarr data, use the Export module. Bulk imports are described in the page Mass imports.
安装
该模块包含在 Dolibarr 发行版中,因此无需安装。
配置
要使用此模块,必须首先使用管理员帐户通过菜单选项 "主页 - 设置 - 模块"启用它:
选择列出模块的选项卡。然后点击 "激活"。。
模块现在已激活。
如果在该模块的行尾出现一个齿轮图标 ,则单击它以访问特定于模块的设置页面。
使用方法
  1. Go to Menu-> Tools -> New Export and choose a predefined dataset.
  2. Choose a predefined (by you) export profile or manually choose the fields you want to include in the export file.
  3. Add any filters you may wish to place on the values of those fields.
  4. Change the position/column of the fields in the export file. You may save the selections you have made as an export profile/template for future use.
  5. Choose a format for the export file from the dropdown list. Possible formats are CSV / TSV (Text files) or XLS 2007 / 95 (native Excel files). Click on Generate.
After few seconds, a link to the file is shown for download.
Outils.png Develop your own export script
If there is no predefined dataset that matches your needes and you have program knowledge, you can also develop your own script. Any language can be used if this language can read a database. You just have to read the table of the entity you want to export and build a file, using the format of your choice, from any fields available in table. The only thing to know is which table contains data you want to export. To help you, the page Table SQL lists all the tables used in Dolibarr.
Note that versions above 2.6 allow "admin" users to see the SQL code that was used to build the export file content when using the Export module. This is shown at the moment of file generation.
相关视频
导出: (法语配音,但字幕可用,并用法语审查)
