Module Workstation
Revision as of 18:40, 6 September 2023 by Udo.tamm (talk | contribs)
Bill Of Materials
Numero/ID of module
Developer doc. of module Module Workstation (developer)
Module Workstation is stable releases with Dolibarr 18.
With this module you can manage your workstations.
This module is useful for / and needs Module Manufacturing Order.
On product with type "Service" (See [Module Services]), you can set the workstation to use to execute the manufacturing process.
