PHP (en)
Revision as of 18:23, 6 September 2023 by Udo.tamm (talk | contribs)
PHP
see Wikipedia PHP
PHP is required for running Dolibarr.
With the further development of Dolibarr also the supported or needed PHP versions can change.
So you should have a look into version requirements before you install or upgrade.
PHP min. = minimum required PHP version
PHP max. = maximum tested & supportet Version with release date
You must install PHP before you run Dolibarr setup
or use a Dolibarr autoinstaller package
which contains PHP and all other necessary elements for your Dolibarr environment.
