Module Workflow
Revision as of 10:54, 5 September 2023 by ShengGang (talk | contribs) (Add Chinese)
Workflow
Numero/ID of module 6000
User doc. of module Cette page
Developer doc. of module Module Workflow (development)
This module allows you to install some workflow links to have automatic object creation. for example, when closing a commercial proposal with status "signed", this module will can automatically an order.
Life cycle / Business rules
This module show only available workflows according to activated modules.
Related videos
