Module Webhook
Revision as of 07:12, 30 August 2023 by Eldy (talk | contribs) (→‎Execution)
The module WebHook add the possibility to send a JSON message to an external URL, on a triggered Dolibarr event.
Add a target
The only configuration needed for this module is adding a target. This is done by going into the module configuration, then click on the menu target. Then just click on the plus sign on the top right of the page, fill one or multiple trigger event and to add an URL to the site we want to post the JSON. You can find information on Trigger event on the wiki page Triggers.
Exemple:
Execution
So once setup is done, each time a business event occurs in Dolibarr for the triggers defined into the setup, a call will be done to the targeted URL. The message will be a JSON message like this example:
   "triggercode" : "TRIGGER_CODE",
   "object" : {DolibarrObject}
Exemple of message sent by Dolibarr when the event COMPANY_CREATE is executed:
     "triggercode":"COMPANY_CREATE",
     "object":
          "id":39,"entity":1,"element":"societe","fk_element":"fk_soc","table_element":"societe","table_element_line":"","ismultientitymanaged":1,
          "import_key":"","array_options":{"options_height":"","options_weight":"","options_prof":"","options_birthdate":false},
          "restrictiononfksoc":1,"context":[],"canvas":"","ref_ext":"","status":"1","country_id":"117","state_id":"0",
          "multicurrency_code":"EUR","note_public":"","note_private":"","comments":[],"name":"Test Webhook",...
