Module Multi-currency
Multi-currency | |
Numero/ID of module | |
Developer doc. of module | {{{devdoc}}} |
This native module add the support for multi-currency in Dolibarr ERP CRM.
- Go into the setup page of the module.
- Enable all the different currencies you need with their rate compared to your main currency (the currency used for the accountancy of your company).
