Module Time Tracker
Revision as of 11:37, 7 July 2023 by Speaking services (talk | contribs) (Purchase Link updated)
Module name Time Tracker
Editor / Editeur Speaking Services - http://2geeks.me
Download or buy page / Page achat ou téléchargement External module - www.dolistore.com/en/modules/1875-Time-Tracker.html
Last update date / Date mise à jour fiche / Fecha última actualización 2023-07-7
Note / Nota {{{note}}}
This module allows to track the time spent on working for a specific customer and to facilitate the billing process for the corresponding services. The main focus of this TimeTracking module is not only to measure the time spent on a specific service, but also to save time in the administration and billing of that service.
From the application
Manually
unzip modulefile.zip
