Module Time Tracker
Module name | |
Editor / Editeur | Speaking Services - http://2geeks.me |
Prerequisites / Prérequis |
Dolibarr min version: 2.6.0 Dolibarr max version: {{{maxversion}}} |
Last update date / Date mise à jour fiche / Fecha última actualización | 2023-07-7 |
Note / Nota |
This module allows to track the time spent on working for a specific customer and to facilitate the billing process for the corresponding services. The main focus of this TimeTracking module is not only to measure the time spent on a specific service, but also to save time in the administration and billing of that service.
From the application
Manually
unzip modulefile.zip
