Module Time Tracker
Module name | |
Editor / Editeur | {{{editor}}} |
Status / Statut / Estado | |
Prerequisites / Prérequis |
Dolibarr min version: {{{minversion}}} Dolibarr max version: {{{maxversion}}} |
Last update date / Date mise à jour fiche / Fecha última actualización | 2023-07-7 |
Note / Nota | {{{note}}} |
SpeedFinder adds a menu to quick search for a contact or a company by entering a few digits of the phone.
From the application
Manually
unzip modulefile.zip
