休假模块
Holiday
模块ID
用户手册 本页
开发文档 Module Holiday (developer)
简介
使用休假模块,您可以提交和跟踪休假请求。
安装
该模块包含在 Dolibarr 发行版中,因此无需安装。
配置
要使用此模块,必须首先使用管理员帐户通过菜单选项 "主页 - 设置 - 模块"启用它:
选择列出模块的选项卡。然后点击 "激活"。。
模块现在已激活。
如果在该模块的行尾出现一个齿轮图标Cog.png,则单击它以访问特定于模块的设置页面。
生命周期 / 业务规则
一个休假申请遵循以下生命周期:
    /                       /---------------------->---------> E-Canceled
A-Draft --> B-Validated/Waiting approval --> C-Approved
   |                        ---------------> D-Denied <--|
  • A) “草稿”状态意味着休假申请尚不存在。其正式版本尚未完成。
  • B) “已验证”状态也意味着处于“待批准”状态。当您验证休假申请时,将向主管发送电子邮件。
  • C) 具有“批准休假”权限的主管可以批准休假申请。
  • E) 尚未获得批准的休假申请可以被申请者取消。如果想稍后重新提交此休假申请,可以将其设置回"草稿"状态。
Create a leave
Validate a leave
To validate a leave, go on its card (you can find record from menu HR - Leave - List).
Then click on button *Validate and submit for approval*. An email will be sent to supervisor of user (or another user if leave creator ask a validation by another approver).
Modify a leave
To modify a leave, go on its card (you can find record from menu HR - Leave - List).
You can edit it if leave has draft status. If not click on action button Back to draft.
Approve/Deny a leave
To approve or deny a leave, go on its card (you can find record from menu HR - Leave - List). Note that user need permission *Approve/Deny leave* to be able to approve or deny a leave.
Delete a leave
To delete a leave, go on its card (you can find record from menu HR - Leave - List . You need permission *Delete leaves* for this. Usually, few people has this permission since deleting is not useful compared to cancel/deny status.
Then click on action button Delete.
Warning, a deleted leave is definitively removed with no way to restore it.
Related videos
