休假模块
| Holiday | |
| 模块ID | |
| 用户手册 | 本页 |
| 开发文档 | Module Holiday (developer) |
简介
使用休假模块,您可以提交和跟踪休假请求。
安装
该模块包含在 Dolibarr 发行版中,因此无需安装。
配置
要使用此模块,必须首先使用管理员帐户通过菜单选项 "主页 - 设置 - 模块"启用它:
选择列出模块的选项卡。然后点击 "激活"。。
模块现在已激活。
如果在该模块的行尾出现一个齿轮图标
,则单击它以访问特定于模块的设置页面。
Life cycle / Business rules
An expense report follow the following life cycle:
/ /---------------------->---------> E-Canceled
A-Draft --> B-Validated/Waiting approval --> C-Approved
| ---------------> D-Denied <--|
- A) Draft status means the leave does not exists yet. Edition is not yet finished.
- B) Status validated means also "waiting for approval". When you validate a leave, an email is sent to the supervisor.
- C) A supervisor with permission "Approve leaves" can approve the leave.
- E) The author of leave can cancel it if status is not yet approved. He can then send it back to draft if he want to resubmit it later.
Create a leave
Validate a leave
To validate a leave, go on its card (you can find record from menu HR - Leave - List).
Then click on button *Validate and submit for approval*. An email will be sent to supervisor of user (or another user if leave creator ask a validation by another approver).
Modify a leave
To modify a leave, go on its card (you can find record from menu HR - Leave - List).
You can edit it if leave has draft status. If not click on action button Back to draft.
Approve/Deny a leave
To approve or deny a leave, go on its card (you can find record from menu HR - Leave - List). Note that user need permission *Approve/Deny leave* to be able to approve or deny a leave.
Delete a leave
To delete a leave, go on its card (you can find record from menu HR - Leave - List . You need permission *Delete leaves* for this. Usually, few people has this permission since deleting is not useful compared to cancel/deny status.
Then click on action button Delete.
Warning, a deleted leave is definitively removed with no way to restore it.
Related videos
