休假模块
Revision as of 04:11, 5 July 2023 by ShengGang (talk | contribs) (初始化)
Holiday
Numero/ID of module
Developer doc. of module Module Holiday (developer)
With the module Holiday you can make and follow leave requests.
Life cycle / Business rules
An expense report follow the following life cycle:
    /                       /---------------------->---------> E-Canceled
A-Draft --> B-Validated/Waiting approval --> C-Approved
   |                        ---------------> D-Denied <--|
  • A) Draft status means the leave does not exists yet. Edition is not yet finished.
  • B) Status validated means also "waiting for approval". When you validate a leave, an email is sent to the supervisor.
  • C) A supervisor with permission "Approve leaves" can approve the leave.
  • E) The author of leave can cancel it if status is not yet approved. He can then send it back to draft if he want to resubmit it later.
Create a leave
Validate a leave
To validate a leave, go on its card (you can find record from menu HR - Leave - List).
Then click on button *Validate and submit for approval*. An email will be sent to supervisor of user (or another user if leave creator ask a validation by another approver).
Modify a leave
To modify a leave, go on its card (you can find record from menu HR - Leave - List).
You can edit it if leave has draft status. If not click on action button Back to draft.
Approve/Deny a leave
To approve or deny a leave, go on its card (you can find record from menu HR - Leave - List). Note that user need permission *Approve/Deny leave* to be able to approve or deny a leave.
Delete a leave
To delete a leave, go on its card (you can find record from menu HR - Leave - List . You need permission *Delete leaves* for this. Usually, few people has this permission since deleting is not useful compared to cancel/deny status.
Then click on action button Delete.
Warning, a deleted leave is definitively removed with no way to restore it.
Related videos
