会员资格管理模块
Foundations | |
模块ID | 310 |
用户手册 | 本页 |
开发文档 | Module Foundations (developer) |
简介
基金会模块用于管理基金会的会员:
- 定义多个会员类型
- 添加/验证/编辑/恢复/删除 会员卡 (特征、照片等 ...)
- Manage subscriptions is required or not.
- Add/Edit/Delete subscriptions.
- With module EMailing, send mass emailings to members or to a selection of members.
- With module LDAP, synchronize members with a LDAP.
- With module Banks and Cash, interface your subscriptions with treasury of your foundation.
- Reporting.
- Generic export with Module Exports.
Creation of a member type
Creation of personalized attributes
New or renew a subscription
Revoke a member
Related videos
