会员资格管理模块
Revision as of 04:03, 4 July 2023 by ShengGang (talk | contribs)
Foundations
模块ID 310
用户手册 本页
开发文档 Module Foundations (developer)
简介
基金会模块用于管理基金会的会员:
  • 定义多个会员类型
  • 添加/验证/编辑/恢复/删除 会员卡 (特征、照片等 ...)
  • Reporting.
Creation of a member type
Creation of personalized attributes
Diagramme d'états d'un adhérent
New or renew a subscription
Revoke a member
Related videos
