会员资格管理模块
Revision as of 03:54, 4 July 2023 by ShengGang (talk | contribs)
Foundations
Numero/ID of module 310
=Introduction
Foundations
模块ID 310
用户手册 本页面
开发文档 Module Foundations (developer)
  • Reporting.
Creation of a member type
Creation of personalized attributes
New or renew a subscription
  Page waiting for translation. To translate, create an account, go back and clic on "Modify".
  Page en attente de traduction. Pour traduire, créez un compte, revenez et cliquez sur "Modifier".
  Página a traducir. Para traducirla, cree una cuenta, vuelva a la página y haga clic en "editar".
  Pagina da tradurre. Per tradurla, crea un utente, torna indietro e clicca su "modifica".
  Página a aguardar por tradução. Para traduzir, crie uma conta, volte atrás e clique em "Modificar".
  Seite wartet auf Übersetzung. Um Übersetzung zu erstellen, richte einen Account ein, geh zurück und klicke auf "bearbeiten".
  页面等待翻译。若要翻译本页,先创建一个帐户、登录并返回本页后单击“编辑”。
Revoke a member
Related videos
