Module Webhook
The module WebHook add the possibility to send a JSON message to an URL after the trigger of a Dolibarr event.
Add a target
The only configuration needed for this module is adding a target. This is done by going into the module configuration, then click on the menu target. Then just click on the plus sign on the top right of the page, fill one or multiple trigger event and to add an URL to the site we want to post the JSON.
Execution
So once setup is done, each time a business event occurs in Dolibarr for the triggers defined into the setup, a call will be done to the targeted URL. The message will be JSON message like this example:
   "triggercode" : "TRIGGER_CODE",
   "object" : {DolibarrObject}
Exemple:
     "triggercode":"COMPANY_CREATE",
     "object":
          "id":39,"entity":1,"element":"societe","fk_element":"fk_soc","table_element":"societe","table_element_line":"","ismultientitymanaged":1,
          "import_key":"","array_options":{"options_height":"","options_weight":"","options_prof":"","options_birthdate":false},
          "restrictiononfksoc":1,"context":[],"canvas":"","ref_ext":"","status":"1","country_id":"117","state_id":"0",
          "multicurrency_code":"EUR","note_public":"","note_private":"","comments":[],"name":"Test Webhook",...
