Module Webhook
Revision as of 15:42, 14 June 2023 by Eldy (talk | contribs)
The module WebHook add the possibility to send a JSON message to an URL after the trigger of a Dolibarr event.
Add a target
The only configuration needed for this module is adding a target. This is done by going into the module configuration, then click on the menu target. Then just click on the plus sign on the top right of the page, fill one or multiple trigger event and to add an URL to the site we want to post the JSON.
JSON format
   "triggercode" : "TRIGGER_CODE",
   "object" : "Dolibarr object"
