Integration of Dolibarr to the n8n automation platform
Revision as of 11:58, 24 May 2023 by Eldy (talk | contribs)
Prerequisites
The following tutorial assumes that you have completed the following prerequisites:
  • You have access to an instance of Dolibarr configured to use SSL encryption (with the HTTPS protocol)
  • You have a Dolibarr administrator user account to access it
  • You have activated the “Web Services API REST” module (if it is not already the case, follow the official documentation)
  • You have obtained an API key for your user account that you will use to test your integration (generated by an administrator, or by the user himself if he has permission to modify his user account information)
When necessary, we will use the following URL to refer to your Dolibarr instance: https://yourdolibarrurl. You will have to replace it with the URL of your own Dolibarr instance, without trailing slash.
In n8n, there are two types of nodes: actions and triggers. In this tutorial, we will focus on building a declarative-style action node that creates an event in Dolibarr’s agenda module.
Setting up a self hosted n8n
As an average user, there are many ways through which you can use n8n. However, as a developer, you need to be able to test your node locally. As a result, this tutorial will assume you will be developing your node on n8n self-hosted through npm.
Building a node
On this page, you will find a tutorial for creating a node (n8n app integration). This includes:
  • An explanation of the different styles to build a node (programmatic or declarative)
  • A tutorial for each building style
  • A page that lists the different UI elements you will be able to use in your node
From now on, this tutorial will focus on explaining how to build the operation “Create an event” which covers a wide range of what is possible with n8n.
Setting up your environment
This tutorial assumes you are at least vaguely familiar with JavaScript, TypeScript, and REST APIs. You should also know how to use git: at the very least to be able to publish your node once it is done. Finally, you should know how to create and submit packages on npm.
On your computer, you should have:
  • Node.js and npm (minimum version Node 16)
  • A local instance of n8n (run npm install n8n -g on your terminal to install it)
n8n recommends that you use Visual Studio Code as your IDE and that you install the following extensions:
  • ESLint
  • EditorConfig
  • Prettier
By using VS Code and these extensions, you get access to the n8n node linter’s warnings as you code.
Node file structure
Must be included in your file structure:
  • A package.json file (necessary for any npm module)
  • A nodes directory containing all your source files for your node
    • This directory must contain a base file named <node-name>.node.ts (in our case, it will be called Dolibarr.node.ts)
    • It is recommanded to have a codex file, containing metadata for your node and matching the node base file name (Dolibarr.node.json)
  • A credentials directory containing your credentials code (one file per node). In our case, it will be called Dolibarr.credentials.ts
Once the node starts to become complicated, n8n recommends the following structure:
  • actions: directory with description and implementation of each possible resource and operation.
    • In the actions folder, n8n recommends using resources and operations as the names of the sub-folders.
    • For the implementation and description you can use separate files. Use execute.ts and description.ts as filenames. This makes browsing through the code a lot easier. You can simplify this for nodes that have a less complicated structure.
  • methods: an optional directory dynamic parameters’ functions.
  • transport: a directory containing the communication implementation.
Should you include more than one node in the npm package, each node should have its own directory in nodes
Setting up the project
The easiest way to start a new project is to generate a repository from the n8n-nodes-starter template, clone your new repository and then delete the following files and directories:
  • nodes/ExampleNode/
  • nodes/HTTPBin/
  • credentials/ExampleCredentials.credentials.ts
  • credentials/HttpBinApi.credentials.ts
From there, you can create the directory and files necessary for our node:
  • nodes/Dolibarr/
  • nodes/Dolibarr/Dolibarr.node.ts
  • nodes/Dolibarr/Dolibarr.node.json
  • credentials/DolibarrApi.credentials.ts
Now, install the project dependencies:
npm i
Save the Dolibarr logo as an svg file in the nodes folder.
Creating the node
The next few sections will all be happening in the Dolibarr.node.ts file.
Imports
Start by adding the import statement:
import { INodeProperties, INodeType, INodeTypeDescription } from 'n8n-workflow';
Creating the main class
A node must export an interface that implements INodeType. We need to have a description interface that contains the properties array.
export class Dolibarr implements INodeType {
    description: INodeTypeDescription = {
        // Basic node details will go here
        properties: [
        // Resources and operations will go here
Adding node details
Now, we add basic parameters such as the display name, the icon, and the basic information for making a request using our node. In description, just before properties, we add:
        displayName: 'Dolibarr',
        icon: 'file:dolibarr_logo.svg',
        group: [],
        version: 1,
        subtitle: '={{$parameter["operation"] + ": " + $parameter["resource"]}}',
        description: 'Add data to Dolibarr',
        defaults: {
        inputs: ['main'],
        outputs: ['main'],
        credentials: [
                required: true,
        requestDefaults: {
            returnFullResponse: true,
            baseURL: '={{$credentials.baseUrl}}/api/index.php',
            headers: {
                Accept: 'application/json',
                'Content-Type': 'application/json',
Here is what each field does:
  • displayName, icon, description, and subtitle are used to render the node in the Editor UI
  • version: the version number of our node
  • defaults: in case the displayName is too long and is not able to be displayed (in our case, the display name is short enough that we can have the same default name)
  • inputs and outputs: where the node inputs and outputs its data (should be ‘main’ in most cases)
  • credentials: the name of our credentials (should match up with the name that will be given in the credentials file)
  • requestDefaults: what model the HTTP requests will be based upon. In our case, it should match the HTTP requests given when you try out the APIs on swagger.
Add resources
The resource object defines the API resource that the node uses. Here, we are creating a node that will create an event in the agenda module in a Dolibarr instance. Update the properties array with the resource object:
properties: [
    // In our case, we should have one resource per Dolibarr module
        displayName: 'Resource',
        type: 'options',
        noDataExpression: true,
        options: [
                value: 'agenda',
            // Add as many options as resources
        default: 'agenda',
    // Operations will go here
type controls which UI element n8n displays for the resource, and tells n8n what type of data to expect from the user. options results in n8n adding a dropdown that allows users to choose one option. More informations here.
Adding operations
The operations object defines the available operations on a resource. In our case, we will probably want one operation per available API. For example, for the agenda module, we have 5 different types of APIs:
  • GET /agendaevents
  • POST /agendaevents
  • DELETE /agendaevents{id}
  • GET /agendaevents{id}
  • PUT /agendaevents{id}
For this tutorial, the one that interests us is POST /agendaevents. > In a declarative-style node, the operations object includes routing (within the options array). This sets up the details of the API call.
Add the following to the properties array, after the resource object (will add an operation):
    displayName: 'Operation',
    type: 'options',
    default: 'createEvent',
    displayOptions: {
        show: {
            resource: ['agenda'],
    options: [
            value: 'createEvent',
            action: 'Create an event',
            routing: {
                request: {
                    method: 'POST',
                    url: '/agendaevents',
        // Add the other operations for the agenda resource here
After that, you can add the following, which will create the fields the user will see in the Editor UI:
        displayName: 'Event Name',
        type: 'string',
        default: '',
        placeholder: 'Name of the event',
        required: true,
        displayOptions: {
            show: {
                operation: ['createEvent'],
        routing: {
            send: {
                type: 'body',
                property: 'label',
        displayName: 'Description',
        type: 'string',
        default: '',
        placeholder: 'Description of the event',
        displayOptions: {
            show: {
        routing: {
            send: {
                type: 'body',
                property: 'note',
        displayName: 'Event Creator',
        type: 'hidden',
        default: '',
        displayOptions: {
            show: {
        routing: {
            send: {
                preSend: [setUserOwnerId],
        displayName: 'Event Type',
        type: 'options',
        default: 'AC_INT',
        placeholder: 'Type of event',
        required: true,
        displayOptions: {
            show: {
        options: [
                name: 'Intervention on Site',
                value: 'AC_INT',
                value: 'AC_RDV',
                name: 'Reception of Email',
                value: 'AC_EMAIL_IN',
        routing: {
            send: {
                type: 'body',
                property: 'type_code',
        displayName: 'Beginning Date of Event',
        type: 'dateTime',
        default: '',
        required: true,
        displayOptions: {
            show: {
        routing: {
            request: {
                body: {
                    datep: '={{$value}}',
            send: {
                preSend: [formatDateP],
        displayName: 'End Date of Event',
        type: 'dateTime',
        default: '',
        required: true,
        displayOptions: {
            show: {
        routing: {
            request: {
                body: {
                    datef: '={{$value}}',
            send: {
                preSend: [formatDateF],
        displayName: 'Email From',
        type: 'string',
        default: '',
        placeholder: 'Email From',
        displayOptions: {
            show: {
        routing: {
            send: {
                type: 'body',
                property: 'email_from',
        displayName: 'Email Subject',
        type: 'string',
        default: '',
        placeholder: 'Email Subject',
        displayOptions: {
            show: {
        routing: {
            send: {
                type: 'body',
                property: 'email_subject',
Each object corresponds to one user input. Let us explain what each field does using the following example:
        type: 'string',
        default: '',
        required: true,
        displayOptions: {
            show: {
        routing: {
            send: {
                type: 'body',
                property: 'label',
This object corresponds to the following user input:
  • displayName is the label just above the user input box
  • name is the internal name of the object
  • The placeholder is what the user can see before starting to type in the box
  • In displayOptions you should put the values for which that user input is shown. In this case, the user input for the name of an event will only appear is the user hase selected the agenda resource and the createEvent operation.
  • In routing, you deal with how your HTTP request will be built. In our case, we will send an HTTP request with a JSON body and the user input will be associated with the field label (given by the property field).
  • type is the Node UI element
Hidden fields
You might have noticed that in the Add Resources section, we are missing a field for userownerid that is a mandatory field when making the API request. However, an average user would have no way of knowing his user id on Dolibarr. That is why we hid the user input and fill it in automatically. Add this object after all the others:
        type: 'hidden',
        default: '',
        displayOptions: {
            show: {
        routing: {
            send: {
It’s value is set before being sent (hence the preSend field) in a function called setUserOwnerId found in another file. More about this in Functions section.
Adding optional fields
If you want your node to have optional fields, you can do so easily and n8n will display those under Additional Fields in the UI. To add an additional field, it should look like this:
    displayName: 'Additional Fields',
    type: 'collection',
    default: {},
    placeholder: 'Add Field',
    displayOptions: {
        show: {
            resource: [
                'agenda',
            operation: [
                'createEvent',
    options: [
            displayName: '____',
            type: '____',
            default: '',
            routing: {
                // What you want to do for routing
Functions
The declarative-style for creating nodes is really easy to use but you might want to do some more complex things such as pre-filling a field before sending the HTTP request. This is done by creating functions that you can then use in your object (for instance the object handling the userownerid field in the API). Let us take a look as how that function (setUserOwnerId) works:
export async function setUserOwnerId(this: IExecuteSingleFunctions, requestOptions: IHttpRequestOptions): Promise<IHttpRequestOptions> {
    const responseData = await apiRequest.call(this, 'GET', 'users/info');
    if (requestOptions.body != undefined) {
        Object.assign(requestOptions.body, { userownerid: responseData.id });
    return requestOptions;
This function takes the HTTP request options that would have been sent on the API call as an argument. In the body of the function, we aim to modify the body of the HTTP request. First, through a separate API call, we get the user ID. Then, after checking that requestOptions.body is not undefined, we set userownerid to the value that was received from the API call. Lastly, we return the HTTP request options that were modified.
You might have noticed that the biggest part of that function is done by apiRequest.call. The code for apiRequest can be found below:
export async function apiRequest(
    this: IHookFunctions | IExecuteFunctions | ILoadOptionsFunctions | IExecuteSingleFunctions,
    method: IHttpRequestMethods,
    endpoint: string,
    body: IDataObject | GenericValue | GenericValue[] = {},
    query: IDataObject = {},
): Promise<any> {
    query = query || {};
    type DolibarrApiCredentials = {
        apiKey: string;
        baseUrl: string;
    const credentials = (await this.getCredentials('dolibarrApi')) as DolibarrApiCredentials;
    const options: IHttpRequestOptions = {
        method,
        body,
        qs: query,
        url: `${credentials.baseUrl}/api/index.php/${endpoint}`,
        headers: {
            'content-type': 'application/json',
    try {
        return this.helpers.httpRequestWithAuthentication.call(this, 'dolibarrApi', options);
    } catch (error) {
        if (error instanceof NodeApiError) {
            throw error;
        throw new NodeApiError(this.getNode(), error as JsonObject);
This function is rather simple as well. We define a type for our credentials and we retrieve them. We define the HTTP request options and then use the helper function from n8n to return the result of an HTTP request with authentication.
Setting up authentication
As you might remember, we created a DolibarrApi.credentials.ts file earlier in the beginning of this tutorial. Head to that file and add the following:
import type {
    ICredentialType,
    INodeProperties,
    IAuthenticateGeneric,
    ICredentialTestRequest,
export class DolibarrApi implements ICredentialType {
    name = 'dolibarrApi';
    displayName = 'Dolibarr API';
    properties: INodeProperties[] = [
            displayName: 'Base URL',
            type: 'string',
            required: true,
            default: '',
            placeholder: 'https://yourdolibarrurl',
            displayName: 'API Key',
            type: 'string',
            required: true,
            typeOptions: { password: true },
            default: '',
    authenticate: IAuthenticateGeneric = {
        type: 'generic',
        properties: {
            headers: {
                DOLAPIKEY: '={{$credentials.apiKey}}',
    test: ICredentialTestRequest = {
        request: {
            url: '/users/info',
            method: 'GET',
  • name: internal name of the object, notably used in the Dolibarr.node.ts to access the credentials.
  • documentationUrl: link to credentials documentation.
  • properties: fields we want the user to fill in to authenticate themselves. In our case, that is the base URL to their Dolibarr instance and the API key associated with their user profile.
  • authenticate: how to inject the authentication data as part of the API request. In our case, we need a DOLAPIKEY in the headers.
  • test: how n8n checks that the credentials input are correct.
  • more information here.
Adding node metadata
This is what you need to add to the Dolibarr.node.json file:
    "node": "n8n-nodes-base.Dolibarr",
    "nodeVersion": "1.0",
    "codexVersion": "1.0",
    "categories": [
        "Miscellaneous"
    "resources": {
        "credentialDocumentation": [
                "url": ""
        "primaryDocumentation": [
                "url": ""
In the resources, we should have link to the necessary documentation so that n8n can automatically add help links.
Testing the node locally
  1. Make sure you have installed n8n. If not, you can run
    npm install n8n -g
  2. Publish your node locally:
     # In your node directory
     npm run build
     npm link
    You can also run
     npm run dev
    So that your node will be built each time you make a change
  3. Install the node into your local n8n instance:
    npm list -g
    Should give you something like this
    $HOME/.nvm/versions/node/v18.14.0/lib
    ├── corepack@0.15.3
    ├── n8n@0.218.0
    ├── npm@9.5.1
    └── uuid@9.0.0
    Do the following to create a link between your local node and the nodes directory within your n8n installation:
    cd <first line of previous command>/node_modules/n8n
    npm link <node-package-name>
  4. Start n8n
    n8n start
  5. Open n8n in your browser. You should be able to find your node when you search for them in the nodes panel (just type Dolibarr).
Conclusion
This tutorial helped you build an n8n node that will create an event in Dolibarr. You can find the rest of the node being built here.
Credits
This tutorial was produced by the AuTEAMation team as part of the design of interfacing prototypes between the Dolibarr ERP/CRM and several automation platforms for DoliCloud. This study was carried out as part of the PFA, a 2nd year group project at ENSEIRB-MATMECA.
