Module Shipments
Shipments
Numéro/ID du module 80
Doc développeur du module Module Shipments (developer)
The Shipping module allows you to manage product shipments from a sales order. It becomes possible to follow the quantities dispatched and quantities remaining to be dispatched, to generate a packing slip, to see proof of distribution.
Note: For receptions, see Module Reception.
In standard configuration
When the module is activated, it becomes possible to create a shipment from a sale order. The workflow for an expedition is as follows:
Draft (0) ---X---> Validated = Prepared / To ship or Shipped (1) ---X---> Processed (Closed / Shipped) '' (2)
Note:
  • For status other than "Draft", the quantity can no longer be modified.
  • Number in parenthesis: Numeric value of the status in the database
  • X means that the stock can be automatically decremented during this step (depending on the stock decrement configuration of Stock Module).
TODO Evolution to plan:
  • Can edit a shipment when in draft mode. Move form used in create mode into the edit draft page. Add a button to switch (one warehouse / all warehouse) ?
  • When the module "Lot" is on, you must be able to enter the batches and change quantity before going to closed/shipped.
  • Make it possible to modify the number shipped when the shipment is in "Validated" status. It will then be possible to create good shipments WITHOUT an order, serving as a preparation order without an order ?
With the hidden option WORKFLOW_BILL_ON_SHIPMENT (not supported, unstable)
If the hidden option WORKFLOW_BILL_ON_SHIPMENT is set, the Closed step is replaced by Billed.
Draft (0) --X--> Validated (1) ---> Invoiced (2)
TODO This option should disappear in favor of a separation of ClassifyBilled and ClassifyClosed which must be de-correlated.
It requires:
  • Addition of an invoiced field / status (apart) called "billed" in the shipment table.
Note
Depending on the configuration of the Stock module, the stock can be decremented by:
  • Validation of shipments.
  • Closing a shipment.
For companies managing shipments, the Closed step can also mean the udder in charge by the carrier, the Validated step being the processing of the order internally (making the package, issuing the BL)
