Security information
Alerts
Last update: 2023-03-18
A vulnerability allowing a user to get the list of contacts (name, firstname and id in database) has been discovered. Fix is available into 18.0.1and higher versions.
Note: You can also download from GitHub the intermediate versions (not yet released maintenance package) for all branches/version (https://github.com/Dolibarr/dolibarr/)
Security Features
Dolibarr implements several security features to match best practices rules related to security.
This is a list of main security features you can find :
Encryption
- Passwords or security keys data are encrypted in database [*7] [*8].
- The database technical password can be obfuscated into the Dolibarr configuration file (conf.php) [*8].
- Possibility to force HTTPS [*9].
//conf/conf.php file
//example of $dolibarr_main_force_https configuration
$dolibarr_main_force_https = '1';//to force https
| Values | Description |
0 |
No forced redirect |
1 |
Force redirect to https, until SCRIPT_URI start with https into response |
2 |
Force redirect to https, until SERVER["HTTPS"] is 'on' into response |
Force redirect to the https domain name mydomain (recommended method) |
Hacks and cracks
- Works with register_globals on or off (off highly recommended) [*2].
- Works with PHP safe_mode on or off (on recommended) [*3].
- Production mode to disable any technical information leakage like debug, error stacktrace, version informations (See configuration file) [*6].
- Protection against SQL injection. Protected by an Internal WAF, and unit test to check database good practice for escapement. [*2].
- Protection against XSS injection (Cross Site Scripting). Protected by an internal WAF and web page headers. [*1].
- Protection against SSRF.
- Protection against CSRF (Cross Site Request Forgery). Protected by an internal WAF and a token system. [*5].
Note that it is also recommended to protect your web server by disabled Apache option
AcceptPathInfo Off
Pages and files access
- Pages and contents are protected by centralized entry code to check permissions (granted on groups or users for each functional module) [*4] [*10].
- Files saved by Dolibarr are stored in a different root directory than web application (so they can't be downloaded without passing by the Dolibarr wrapper) [*3] [*10]. Note: You must check that you did not choose the "document" directory (for upload files) to be in same directory neither in a sub-directory than the "htdocs" directory. You web virtual host must point to the htdocs directory only (and this directoy can/should be in read only mode). So any uploaded file (stored into the document directory) can't be download without using the wrapper page.
- Dolibarr directories content can't be accessed even if Apache option Indexes has been forgotten to on (should not) [*3].
Login protection
- Delay anti brute force cracking on login page [*7]. Currently this delay is fixed (May be exponential with tries in a future version).
- Option for graphical code (CAPTCHA) against robots on login page [*7].
- Restrict access to backoffice for some IP only [*7].
- No passwords in logs, even in technical logs [*7].
- Internal logger to save permanently all Dolibarr events about user's administration and successful or failed logins or administration events (user or group or permission changes).
- Can output a log record into a log file (module Debug Log must be enabled with at least level 5-LOG_NOTICE on production server, higher on development server) after success or failed login attempt so you can add a fail2ban rule to lock brute force cracking. You can check record with syntax :
"YYYY-MM-DD HH:MM:SS (ERROR|NOTICE|INFO|DEBUG) IP functions_dolibarr::check_user_password_.* Authentication KO"
A list of fail2ban rules to add to your server is provided on chapter DOS and Brute force rate Mitigation later.
Viruses
- Possibility to run an external anti-virus on every uploaded files [*3].
Security Information Center
- From version 14, you will find into menu Home - Admin tools - Security, a security information center that report you all recommandations done and to do related to your installation.
A CTI for security
A continuous integration platform run Security unit tests and static code analysis on each modification of code.
A footprint for each version
Our release process bring each version with a footprint file (also available online) to validate all files of your local installation.
Note: Dolibarr conforms to the Best Practices defined by the OpenSourceSSF: https://bestpractices.coreinfrastructure.org/projects/5521
The project provide examples of some fail2ban rules to block brute force attempts or abusive access on login page, password forgotten page and on any public pages. See https://github.com/Dolibarr/dolibarr/tree/develop/dev/setup/fail2ban
Report a security vulnerability
- To report a vulnerability, see the file: https://github.com/Dolibarr/dolibarr/blob/develop/SECURITY.md
- If you are allowed, you can also use the security feature of GitHub on https://github.com/Dolibarr/dolibarr/security
In most cases, security reports are processed in few days only.
(*X) This solution is part of protection used to solve vulnerabilities classified by the OWASP Top Ten at range number X.
