Module DAV
Revision as of 08:59, 17 January 2023 by Eldy (talk | contribs)
DAV
Numero/ID of module
Developer doc. of module Module DAV (developer)
The DAV module add a WebDAV server component to Dolibarr, that you can access with any WebDAV client.
You can offer a shared public directory (no login required) and/or a private directory (need to use a Dolibarr login).
The content of the manuel directory of the Module ECM can also be accessed (need to use a Dolibarr login).
For the section that are protected by a login, Dolibarr use a HTTP Basic authentication. So if you already protected your Dolibarr directory with a HTTP Basic authantication protection, you must exclude the path */dav* from this protection to avoid a duplicate HTTP Basic authantication that will conflict. For example, if your directory is protected by
<Directory "/my-path-to-my-dolibarr-hdocs">
AuthType Basic
AuthName "Restricted Files - HTTP Basic protection on Dolibarr"
AuthUserFile "/pathtohttpbasicpasswords"
Require user ahttpbasiclogin
</Directory>
You must add an exclusion like this one, so accessing the /dav features will use the HTTP Basic embeded into the DAV component instead of the generec HTTP Basic protection
<Directory "/my-path-to-my-dolibarr-hdocs/dav">
Require all granted
</Directory>
Just go on setup page to get the WebDAV root URL. Use any WebDAV client to access it. All enabled WebDAV directories are subdirectories of the root URL.
