Draft:Specification Module Public Portal
Specification for a module of a Public Portal
We need a new module to offer a public portal
Some requirements
- Must be a Dolibarr module called "WebPortal"
- The portal must be pages hosted into /public/webportal/
Login
A table already exists to store login/pass for external portals. It is already used to store : - login from external website (for example stripe customer key of a thirdparty). The column site contains "stripe". - login from website for users of a website. The column site contains "dolibarr_website" and we store the id of website into fk_website So we will also use it to store login for the external portal: - the column "site" will contains "dolibarr_portal" and fk_soc will contains the id of the thirdparty
On the record of a thirdparty, the module Public portal must enable the new tab will be visible to show all accounts/login (=record of table llx_societe_account) linked to this thirdparty.
Note: This tab already exists but is enabled only when WEBSITE_USE_WEBSITE_ACCOUNTS is on. We found this into core/lib/company.lib.php
if (isModEnabled('website') && (!empty($conf->global->WEBSITE_USE_WEBSITE_ACCOUNTS)) && ($user->hasRight('societe', 'lire'))) {
We must enable the tab also when the module WebPortal is on.
Setup page of the module
The setup page must allow to enable features in the portal like:
- Enable access to the membership record (Hidden / Visible or Editable)
- Enable access to the partnership record
Other need will be added in the future...
