Webserver
Revision as of 08:25, 21 December 2022 by Jmbc (talk | contribs) (→‎Example of setup of a virtual host file for Apache)
A Webserver is necessary for running Dolibarr.
Usually the Apache 2 Webserver is used but you can also use Nginx, or any Web server with PHP support available.
With a root access, create the configuration file /etc/apache2/sites-available/dolibarr.conf
Insert the following lines :
<VirtualHost *:80>
    LogLevel info
    ServerName dolibarr.local
    ServerAdmin admname@mail.com
    DocumentRoot /var/www/dolibarr
    ErrorLog ${APACHE_LOG_DIR}/error.dolibarr.log
    CustomLog ${APACHE_LOG_DIR}/access.dolibarr.log combined
</VirtualHost>
ServerName is the URL base. You will use it in your web browser to access to Dolibarr. ServerAdmin should not use a real mail address.
Activate the configuration :
a2ensite dolibarr.conf
Restart the apache server :
systemctl reload apache2
Example of setup of a virtual host file for Nginx
Here is a configuration file for Nginx working in HTTPS on Debian 11, PHP7.4, Nginx 1.18 et Dolibarr 14 :
server {
       root /var/www/dolibarr/htdocs;
       index index.html index.php;
       server_name dolibarr.example.fr;
       location / {
               try_files $uri $uri/ =404;
       location ~ [^/]\.php(/|$) {
               fastcgi_intercept_errors on;
               include         fastcgi_params;
               fastcgi_param   SCRIPT_FILENAME $document_root$fastcgi_script_name;
               fastcgi_param   SCRIPT_NAME $fastcgi_script_name;
               fastcgi_pass unix:/run/php/php7.4-fpm.sock;
   listen [::]:443 ssl ipv6only=on;
   listen 443 ssl;
   ssl_certificate /etc/letsencrypt/live/dolibarr.example.fr/fullchain.pem;
   ssl_certificate_key /etc/letsencrypt/live/dolibarr.example.fr/privkey.pem;
   include /etc/letsencrypt/options-ssl-nginx.conf;
   ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem;
   error_log /var/log/nginx/dolibarr.example.fr/error.log warn;
   access_log /var/log/nginx/dolibarr.example.fr/access.log;
server {
   if ($host = dolibarr.example.fr) {
       return 301 https://$host$request_uri;
       listen [::]:80;
       listen 80;
       return 404;
