Module Accounting Simplified
Revision as of 18:06, 24 October 2022 by Techsc (talk | contribs) (→‎Related videos: Not in the language of the page but it's better than nothing or it can help)
Accountancy
Numéro/ID du module 10
Doc développeur du module Module Accounting (developer)
This module allows you to get simplified accounting reports. If you need to make double entry accounting, or edit a ledger, you should use instead the Module Double Entry Accounting.
Use
This module contain a ledger that enable you to manually add transactions. However this is not recommended for most transactions.
Transactions from the standard sell and purchase journals can easily be committed to the ledger after they have been assigned valid accounts.
The module also contains a balance sheet for you to see the total income and expense of you company.
Life cycle / Business rules
Related videos
Accounting Simplified: (vocal in french but subtitles are available and review in this language)
