Module CustomizeForms
Revision as of 10:39, 12 October 2022 by Paulorcdo (talk | contribs) (→‎Features: dfdf)
Module name CustomizeForms
Editor / Editeur paulorcdo - https://www.trucolivre.com.br/dolibarr/
Download or buy page / Page achat ou téléchargement External module - On [1]
Last update date / Date mise à jour fiche / Fecha última actualización 2022-10-12
Note / Nota Module CustomizeForms
Logo
Customize Forms allows you to create new features in 25 dolibarr create and edit forms ( + 450 standard fields and + all extra fields)
1- Hide fields in Dolibarr forms;
2- Make fields as mandatory (Javascript);
3- Disable fields in Dolibarr forms;
4- Create Custom Header and Footer in Dolibarr forms;
5- Define default values for fields in Dolibarr forms (texts, lists, html, selection and categories);
6- Create tooltip with instructions on the fields in Dolibarr forms;
7- Create auxiliary lists of preformatted texts and phrases to easily insert into the fields in Dolibarr forms(text, html);
8- Change the presented names of the fields without changing the translations;
9- Define future and past dates in all date fields, just put the default value the text now(0) for current day,  now(+5) for 5 days later, or now(-5) for 5 days before.
10- Leave only pre-defined products and services on the product insertion screen in the budget, order and purchase and sales invoice forms.
2- The module is installed in the Tools menu of Dolibarr, click on the menu and on the left will appear the link Customize Forms.
3- Click on the Customize Forms link and you will be taken to the system home page.
Permissions:
1- Initial system permissions are set with access only to the System Administrator;
2- For new users, the administrator can configure read, edit, and delete permissions on the Dolibarr user or group permissions tab.
Pages
Page 1 - Home Page - List Forms
  • The Home Page lists all 24 Dolibarr forms that can be configured by Customizeforms.
  • The Qty column tells you how many fields can be set on each form.
  • To Customize a Form, just click the pencil on the right form.
HomePage
Page 2 - List All Form Fields to Customize
  • In this example, we click on the Home Page in the New Commercial Proposal - Customer form.
  • This page only displays fields with default values that have already been set. All fields of the form are displayed on this page.
1 - Extrafields that were created for this module will be inserted automatically when you open the page.
2 - The Header and footer fields are options that can be added to the form.
Form
  • Name: Field Name
  • Situation: Current field status - Can be Visible, Invisible, Disabled, or Required.
  • Default Value: Value set to appear as default for the field (text fields, checkbox, selects, textarea).
  • Tag: New Name Defined for Field
  • Auxiliary List: List of Text separated by line breaks that can be added in any text field or textarea.
  • Help Text: Help text that appears when you approach the mouse.
Page 3 - Customizing a form field
In this example, we click in the New Commercial Proposal - Customer form (Page 1) and after we click on the Customer field (Page 2).
To apply module functionality to the form example:
  • To Hide fields:
    • Click in the combo box Define Visibility and Mandatory and select Invisible option (The entire line will be invisible);
  • To Make fields as mandatory (Javascript):
    • Click in the combo box Define Visibility and Mandatory and select Required option;
  • To Disable field:
    • Click in the combo box Define Visibility and Mandatory and select Disable option;
  • To Define default values for field (texts, lists, html, selection and categories):
    • Click in the combo box Set Default Value and select the desired option (Dolibarr options to combo box and checkbox, other field type only write the text to default value);
  • To Change the presented name of the field without changing the translations:
    • Digit new name text to Modify Field Name;
  • To Create auxiliary lists of preformatted texts and phrases to easily insert into the fields (text, html):
    • Digit List of Text separated by line breaks that can be added in any text field or textarea in Create Auxiliary List to insert into text or HTML fields;
  • To Create tooltip with instructions on the fields:
    • Digit html text to Create Tooltip with Help Info;
  • To put the date (future and past) in the date fields :
    • It is possible to define future and past dates in all date fields, just put the text now(0) for the current day, now(+5) for 5 days later, or now(-5) for 5 days previous in the default value, for example;
CustomizeForms
To create Headers and Footers on a form:
1- Choose the form on the home page of the module (Page 1);
2- In the chosen form, click in the Header or Footer field (Page 2);
3- In Page 3:
  • Click in the combo box Define Visibility and Mandatory and select Visible option;
  • Digit new name text to Modify Field Name, this field is a name of Header/Footer in the left table form;
  • Digit html text in the field Set Default Value , this field is a content of Header/Footer in the right table form;
Prerequisites
Partial Features - Dolibarr ≥ 5.0.3
All Features - Dolibarr ≥ 9.0.3
Demo
View DEMO:https://www.trucolivre.com.br/dolibarr user:demo passw:demo
Buy
On https://www.dolistore.com/en/modules/1133-Customize-Forms.html
Video
View Video: https://www.youtube.com/watch?v=wTR9DMnpIck
Outros Módulos
Customize Interface
https://wiki.dolibarr.org/index.php/Module_CustomizeInterface
Categorize All
https://wiki.dolibarr.org/index.php/Module_CategorizeAll
PIX Brasil
https://wiki.dolibarr.org/index.php?title=Module_PIXBrasil
