Module Medical Center
Module name | Medical Center |
Editor / Editeur | DoliCloud - www.dolicloud.com |
Prerequisites / Prérequis |
Last update date / Date mise à jour fiche / Fecha última actualización | 2022-09-1 |
Note / Nota |
Turn your Dolibarr into a medical office manager (dictionaries of pathology, patient management, history, directory of referents doctors, following consultations, examinations/radios, generation of consultation documents, statistics of your consultations, monitoring money input, check receipts, etc ...).
How to use module is described in the usage chapter.
Into setup page dedicated to module, you can also define following options:
- Feature related to rhumatology.
- Hide features to manage customers (you don't need to make invoices).
- Hide features to manage prospects (you don't need to make proposals).
- Field "Bank of patient" is required when payment is a cheque.
Extra fields:
If you miss some fields to qualify your patient, you must go on module Third Party to add extra fields. A patient is a special case of a third party. So adding extra fields on generic Third parties will also be visible on Patient cards.
If you miss some fields to qualify your consultation, go on tab Complementary attributes (Patient) to add missing fields. They will appears on your consultation card.
Other options:
Into menu 'Home - Setup - Other', you can also add constant "CABINETMED_DELAY_TO_LOCK_RECORD" to a number of day. This means all consultation recorded could not be modified 2 days after they were recorded.
By default, standard professional ID fields are not visible when you are on a patient card. You can however decide to make them visible by adding the constant CABINETMED_SHOW_PROFIDx to 1 (where x is a number between 1 and 6 to define which professional ID you want to see. Add several constants, if you need several professional ID).
Data dictionary
The menu "Home - Configuration - Dictionaries" will allow you to change the contents of the following drop-down lists
- Reasons for consultation
- Lesion diagnostics
- Exams
- Conclusions of examinations
- List of bank names
- Patients
- Contacts (the other doctors)
- Consultation summary (show entry/output for a year, month or day of revenus)
Users
Temporary translation When the module is activated, a Dolibarr user is actually a member of caregivers staff (doctor, nurse, midwife, physiotherapist, or secretary ...), and thus a user belonging to the firm using the Dolibarr. There may be only one user in the case of a sole practitioner physician or caregiver. A user can also be a person answering service firm.
Care givers contacts
Correspondents are other caregivers or doctors attending or being occupied Patient. Select the menu "Correspondents" brings up a submenu with the left functions to create, or add a new correspondent.
- To create a contact, just click on the entry "New correspondent" and enter information on the blank page and select Save.
- When selected the menu entry "List all", it means the list of all registered correspondents. If you click on the name of one of them, its card opens. And it is possible to change it.
- It is possible to recall a detail Corresponding quickly by typing part of its name in the quick search box on the left panel.
- With the Statistics menu, it is possible to have statistics of the correspondents (number of patients for whom they are referents for example)
Patients
Select the top menu Patients, brings up a sub-menu offering functions to create a new patient, list patients or past consultations.
- To create a new patient, simply click on the "New Patient" entry and enter the information on the blank sheet and then Save.
- When you have selected the menu entry "Patient List" is the track list of all registered patients. If you click on the name of one of them, his record opens. And it is possible to change it.
- It is also possible to recall the record of a patient quickly by typing part of its name in the quick search box on the left banner.
Create a Patient file or consultations
To create a patient file, click on the menu Patient - New Patient. Once created, a Patient card contains several tabs:
- A tab Patient (which are those recorded during the creation)
- A tad Contacts
- A tab Notes
- A tab Categories (if the Category module has been enabled)
- A tab History / Treatments
- A tab Consultations
- A tab Bio
- A tab Exploration
- A tab Documents / Files
- A tab Event/Calendar (if the Calendar module has been enabled)
Here is a description of how to use each tab.
Tab Patient
Most information on this tab are properties to qualify the patient.
The field "Followed by" has however a specific usage. It is set by default on the user creating the patient. It is possible to assign one or more users (individual doctors cabinet following the patient for example). If the user has permission "Extend acess to all patient", the the user will see all patients. If permission is not granted, then user will see only patient he is a follower of. This information can also be used for some statistics reports.
Tab Contact (tab for correspondents)
(On this tab, you can associate all physicians treating the patient with or knowing their specialty.)
Tab Background / Treatments
To complete ...
Tab Notes
To complete
Tab Consultations
En cliquant sur une fiche Consultation existante ou en cliquant sur le bouton Créer consultation, on ouvre la fiche de consultation.
Sur cette fiche consultation, on va saisir les symptomes remontés par le patient ou détectés, les actes réalisés ou traitements prescrits.
Le montant pris pour la consultation se renseigne également à la fin de la saisie de la fiche.
Tab Bio
Tab Explorations
Tab Documents / Files
- This page allows you to attach attachments (image scanners, ultrasound, papers words ...)
But it also can generate OpenOffice documents from a model. The model is supplied in courrier_consult.odt example.
- To generate a document, choose the model, possibly associated Bio page and click Generate.
The model will be used and all variables tags will be replaced with the patient's information or consultation.
- To make your own document model, see the Create an ODT document template.
The following tags are available in addition to the standard tags of Dolibarr (List of standard tags is avalable on Create an ODT document template:
-- From tab Patient {patient_name} : Patient name {patient_code} : Patient code {patient_barcode} : Patient barcode {patient_barcode_type} : Type of barcode {patient_country_code} : Country code of patient (ex: FR, US, IT...) {patient_country} : Label of country of patient {patient_email} : Patient email {patient_size} : Patient size {patient_weight} : Patient weight {patient_birthdate} : Patient birthdate {patient_profession} : Patient work {patient_gender} : Patient gender {patient_socialnum} : Patient social number {patient_options_xxx} : Extrafield xxx on patient. -- From tab Exploration/Image analysis {examother_title} : Empty string if no image selected when generating the document, otherwise contains the translated value for "Image analysis" {examother_principal} : Empty string if no image analysis selected, otherwise name of exam {examother_conclusion} : Empty string if no image analysis selected, otherwise contains result of exam {examother_principal_and_conclusion} : Empty string if no image analysis selected, otherwise name of exam and result of exam -- From tab Bio analysis {exambio_title} : Empty string if no biology analysis selected when generating the document, otherwise contains the translated value for "Biologic analysis" {exambio_conclusion} : Empty string if no biology analysis selected, otherwise contains result of exam -- From tab consultation {outcome_id} : ID of consultation {outcome_date} : Date of consultation {outcome_reason} : Reason of consultation {outcome_diagnostic} : Diagnostic of consultation {outcome_history} : History of disease. {outcome_exam_clinic} : Exam clinic. {outcome_type_visit} : Type of visit of consultation. {outcome_act_code} : Act code of consultation. -- From tab consultation - Treatments {outcome_treatment_title} : Empty string if no treatment were suggested, otherwise contains the translated value for "Treatment" string {outcome_treatment} : Empty string if no treatment were suggested, otherwise contains the suggested treatment {outcome_exam_suggested} : Exams suggested {outcome_comment} : This is comment added into field "Comment" in the generate document form -- From tab consultation - Payments {outcome_total_inctax_card} : Amount payed with card (including tax) (dolimed 3.4.1) {outcome_total_inctax_cheque} : Amount payed with cheque (including tax) (dolimed 3.4.1) {outcome_total_inctax_cash} : Amount payed with cash (including tax) (dolimed 3.4.1) {outcome_total_inctax_other} : Amount payed with other payment mode (including tax) (dolimed 3.4.1) {outcome_total_inctax} : Amount payed whatever is payment mode (including tax) (dolimed 3.4.1) -- From tab consultation - Extrafields {outcome_options_xxx} : Extrafield xxx on consultation. -- From tab Documents/Files {doc_comment} : The value you enter into the note area before submitting the file for generation.
Example of generated document (click twice to enlarge)
Tab Events/Agenda
(This tab is only visible if the Calendar module has been activated.) (It provides a calendar-type view of certain events that have been recorded on the patient (creation of the patient file, appointments, entering a consultation).)
Menu Statistics
The Statistics menu displays statistics on the number and amount of your consultations in graphical form.
Menu Revenus
The Income menu displays a report of your income. It brings up a table displaying for the last 3 years, the income with the detail by month. It is possible to have a view of each day of the month by clicking on the wording of the month for the sequence. It is also possible from this screen to export the detail in an Excel file.
Example screenshot (click twice on the image to enlarge it):
Menu Report of consultations
Select Balance consultations brings up a table that displays the menu for the past 3 years, income per month with details. Clicking on a month, this place details about each day of the month. It is also possible from this screen to export the details in an Excel file.
Developpement and contributions
Development of this module is not included inside the standard GIT repository of Dolibarr but inside a repository dedicated to modules not supported by the Dolibarr development team but supported by DoliCloud on GitHub:
- GIT Repository: git clone https://github.com/DoliCloud/DoliMed.git
