Module MoceanAPI SMS
<seo metak="module sms, module ovh, send sms" />
Module name MoceanAPI SMS
Editor / Editeur MoceanAPI - https://moceanapi.com
Download or buy page / Page achat ou téléchargement External module - https://dashboard.moceanapi.com/login
  • MoceanAPI account.
  • Dolibarr 3.8+
Last update date / Date mise à jour fiche / Fecha última actualización 2022-07-20
Note / Nota {{{note}}}
  • Send Bulk SMS to third party, contacts and many more.
  • Send SMS to Third Party when invoice is created, updated, validated or paid
  • Send SMS to Contacts when contact is created, enabled or disabled
  • Send SMS to Third Party when project lead status is prospection, qualification, proposal, negotiation.
  • Send SMS to Third Party when Supplier's Order is created, validated, approved, refused, dispatched
  • Send SMS to Third Party when Ticket status changed (created, read, closed, abandoned, assigned)
  • Automatically prefix country code when sending SMS to specific mobile numbers
  • SMS Templates are available for all settings.
  • Plugin / module is translation ready, add / edit files in /langs/ directory
Installations & Activation
  1. Download MoceanAPI Send SMS module from dolistore
  2. Unzip the .zip file you've downloaded into your dolibarr's custom directory
  3. In your dolibarr website, navigate to Setup -> Modules/Application
  4. Activate MoceanAPI Send SMS module under CRM category
To use this module, you will need to register a MoceanAPI Account
After you've installed and activated MoceanAPI Send SMS module
  1. Navigate to MoceanAPI module home page
  2. Enter your Mocean API Key, API Secret, Sender and select the Country under SMS Setting
  3. You're all set and ready to send SMS.
SMS Broadcast
Broadcast SMS to your contacts / third parties easily with MoceanAPI dolibarr module.
  1. Navigate to MoceanAPI module home page and Bulk SMS tab
  2. Filter your contacts / third parties using available criteria until your desired requirement is fulfilled
  3. Once you're done filtering, hit the Send SMS button to broadcast your SMS.
SMS Notification (Automated)
Now you can easily send SMS notification to third party when an event occured. For example, When an Invoice is validated, you can send SMS to remind your customer / client to pay the invoice.
You will find this module very helpful in streamlining your business processes if you're looking to send automated SMS notification to your prospects / customer. This module is for you if you're
  1. In real estate industry looking to remind your tenants to pay their rent on time.
  2. Using dolibarr as your CRM and wants to send automated deals via SMS when your client's sales stage changed (lead -> customer)
  3. Using dolibarr as a Support Ticketing System where you'd want to assure your customers, their concerns is being heard and a solution is on its way.
Currently, the supported module are Invoice, Ticket, Contact, Project, Supplier Order
Did we miss your favourite module or you're looking for a more robust feature ? Shoot us an email here: support@moceanapi.com
