Module Interventions
Interventions | |
Numero/ID of module | 70 |
Developer doc. of module | Module Interventions (developer) |
Interventions are a form for service / maintenance orders.
Default setup
When the module is enabled, it is possible to create intervention files. The workflow of an intervention is the following:
Draft (0) --------> Validated (1) ------> Closed (Done)'' (3) \ / \ / \----------<--------/ \----------<--------/ \ \------> Convert into a recurring intervention
With option FICHINTER_CLASSIFY_BILLED
If the hidden option FICHINTER_CLASSIFY_BILLED is defined, a step Billed is introduced.
Draft (0) -----> Validated (1) --> Billed (2) ----> Closed (Done)'' (3)
Warning, this status/option will be removed. It must be replaced with a property "billed" that can be defined whatever is status "Validated" or "Done".
Life cycle / Business rules
An intervention follows the following life cycle:
Draft --> Validated --> Done
Examples of use cases
UCMI01: | |
Situation | |
Actions |
