Module LavaMailUtilisateur
Module name Lava Mail Utilisateur
Editor / Editeur lavarun.re - https://lavarun.re/dolirun.html#modules
Dolibarr min version: 13.0.0    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2022-06-20
Module allowing the sending of personalized file by user to a group of users. A typical case is the monthly sending of pay slips.
In module setup area
  • LAVATOOLS_PATHFILE ==> Default directory in GED module
  • LAVATOOLS_EMAIL_LIST ==> email list of senders with "," as separator
More info (French only)
Module info by official developer: www.lavarun.re
Technical info and manuals: www.lavarun.re
Acquire the module: www.dolistore.com
Terms of Use, Maintenance and Support: www.lavarun.re
