Module LavaMailUtilisateur
{{TemplateModuleInfo name=Lava Mail Utilisateur |editor=lavarun.re |web=https://lavarun.re/dolirun.html#modules |webbuy= |status=stable |minversion=13.0.0 |note= }}
Module allowing the sending of personalized file by user to a group of users. A typical case is the monthly sending of pay slips.
In module setup area
  • LAVATOOLS_PATHFILE ==> Default directory in GED module
  • LAVATOOLS_EMAIL_LIST ==> email list of senders with "," as separator
More info (French only)
Module info by official developer: www.lavarun.re
Technical info and manuals: www.lavarun.re
Acquire the module: www.dolistore.com
Terms of Use, Maintenance and Support: www.lavarun.re
