Table llx boxes def
Revision as of 07:37, 1 April 2022 by Eldy (talk | contribs)
Content/Contenu/Contenido
Contains the active boxes
Contient les boîtes actives
Contiene las cajas activas.
Structure
Table
Version Dolibarr 15
rowid int(11) NO PRI auto_increment technical index
file varchar(200) NO box file.php
entity int(11) NO 1 multi company id
fk_user int(11) NO 0 if widget is private to one given user
tms timestamp NO Current date Date of last modification. See page Field Tms.
note varchar(130) YES NULL comments
Keys
Version 1.2 2009/10/17
Key Type Fields
PRIMARY PRIMARY rowid
uk_boxes_def UNIQUE file,entity
