A Webserver is necessary for running Dolibarr.
Usually the Apache 2 Webserver is used but you can also use Nginx, or any Web server with PHP support available.
Example of setup of a virtual host file for Apache
TODO...
Example of setup of a virtual host file for Nginx
Voici un fichier de configuration Nginx qui fonctionne en HTTPS pour Debian 11, PHP7.4, Nginx 1.18 et Dolibarr 14 :
server {
root /var/www/dolibarr/htdocs;
index index.html index.php;
server_name dolibarr.example.fr;
location / {
try_files $uri $uri/ =404;
location ~ [^/]\.php(/|$) {
fastcgi_intercept_errors on;
include fastcgi_params;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
fastcgi_param SCRIPT_NAME $fastcgi_script_name;
fastcgi_pass unix:/run/php/php7.4-fpm.sock;
listen [::]:443 ssl ipv6only=on;
listen 443 ssl;
ssl_certificate /etc/letsencrypt/live/dolibarr.example.fr/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/dolibarr.example.fr/privkey.pem;
include /etc/letsencrypt/options-ssl-nginx.conf;
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem;
error_log /var/log/nginx/dolibarr.example.fr/error.log warn;
access_log /var/log/nginx/dolibarr.example.fr/access.log;
server {
if ($host = dolibarr.example.fr) {
return 301 https://$host$request_uri;
listen [::]:80;
listen 80;
return 404;
