Table llx categorie
Revision as of 19:54, 3 July 2021 by Eldy (talk | contribs) (→‎Table)
Content/Contenu/Contenido
  Contains the categories used for the various objects of Dolibarr (providers, products, clients, ...)
  Contient les différentes catégories des différents "objets" de Dolibarr (fournisseurs, produits, clients, ...)
  Contiene las diferentes categorías de los diferentes "objetos" de Dolibarr (proveedores, productos, clientes, etc)
Structure
Table
rowid int(11) NO PRI auto_increment technical index
ref_ext varchar(255) YES External ref
entity int(11) NO UNI 1 multi company id
fk_parent int(11) YES UNI NULL Parent tag of this tag
label varchar(255) YES UNI NULL label (name)
type tinyint(4) NO UNI 1 type of object of this category (0=products, suppliers=2 ,...)
description text YES NULL description a little longer. May contain HTML Code
fk_soc int(11) YES NULL Not used. Used only when option CATEGORY_ASSIGNED_TO_A_CUSTOMER is set.
visible tinyint(4) NO 1 visibility (0=hidden, 1=visible)
color varchar(8) NO color for tag
Keys
Key Type Fields
PRIMARY PRIMARY rowid
uk_categorie_ref UNIQUE entity,fk_parent,label,type
idx_categorie_type MULTIPLE type
idx_categorie_label MULTIPLE type
