Module Inventaire
Module name | Inventaire |
Editor / Editeur | Dolibarr |
Prerequisites / Prérequis | PHP >= 7.2
Dolibarr min version: 14.0 Dolibarr max version: {{{maxversion}}} |
Last update date / Date mise à jour fiche / Fecha última actualización | 2021-06-22 |
Note / Nota |
Pour configurer le module Inventaire le module Module Stock doit être configuré.
Si les permissions avancées sont activées, en supplément il faudra donner les permissions qui se trouvent dans la section Stock des permissions.
Trouver le module
Pour trouver le module il faudra cliquer sur "Produits | Services" dans barre de navigation en haut. Puis cliquer sur "Inventories" dans la barre de navigation à gauche pour accéder à la liste des inventaires.
Initialize a new inventory
Initializing a new inventory is the first step for inventory. You can create a new inventory on the Products/Services tab, clicking Inventories on the plus sign in top right of the screen.
The only requirement to create a new inventory is a label and the other fields are optional. You can decide to make an inventory for a given warehouse or for a given product only, or a complete inventory.
Making the inventory
To make the inventory, you need at first to click on the button "Validate (start)".
Next you need to switch to the tab "Inventory" on top next to the tab "Card". The inventory has been initialized with all the products/warehouses and quantities we should get.
Now you can start your inventory and you can fill the column "Real Qty" for each row. To help in that task the module permit to fill real quantity by scanning object with bar-codes or it permits to fill the real quantity with expected quantities. You can also manually add a new line if you find a new product that was not already referenced by the inventory initialization.
Don't forget to click on Save button on the bottom on the page to save the changes.
Finishing an inventory
This is the step where stock movement will be recorded to update your current stock to the value your entered at the previous step.
To achieve this step you need to use button "Generate movements and close".
When done, your inventory is closed and all stock modifications are done.
